Old 08-14-2019, 11:50 AM   #15
SSDan
SSDan's Avatar
Drives: 2016 1SS 6MT NPP
If turning it back was the case that should have been mentioned
I think the mindset was that of a grudge race (don't over talk about your strategy to others). Ron and V wanted the win - just look at how hard he fought and pushed back on the autocross rules to make his point. I doubt we'll learn if they turned down the wick to make sure the car hooked and won. They didn't need a hero run to win. They didn't want to break the car before the end of the overall contest.
I believe the tune for the dyno run was probably pushing the edge. I doubt they would put a customer's car on the street on that tune - they'd dial it back to be safer.
I say all of this as its what makes sense to me about the track times versus the dyno numbers. I'm speculating of course - just like everyone else - since none of us were there to know for sure.
476 rwhp/440 rwtq (sold)
Old 08-14-2019, 11:54 AM   #16
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
I still don't see the LT4 fuel system supporting 950whp on C9 without meth. I believe Jenetty said LT4 stuff was good for 800-850whp on ms109 with a bigger lobe.
2016 NFG 1SS A8
Options-2SS Leather/NPP
Old 08-14-2019, 11:59 AM   #17
DapperDan
DapperDan's Avatar
Drives: 2017 1SS A8 Nightfall Gray
So besides this. What is the most anyone has seen out of the Lt4 fuel system with cam lobe on Racing Gas?
DapperDan is offline   Reply With Quote
Old 08-14-2019, 12:00 PM   #18
DapperDan
DapperDan's Avatar
Sorry u just answered.....lol
Old 08-14-2019, 12:19 PM   #19
parish8
Drives: 17 SS a8
I saw someone mention 5000’ If this was at 5000’ It likely made 750 actual hp and only needed enough fuel for 750hp. Correction factors get way off for boosted cars up high.
Old 08-14-2019, 02:06 PM   #20
laynlo15
laynlo15's Avatar
Drives: 2022 Lt1 A10
I think I can make a little more, probably 875 with another smaller pulley but I don't see anymore then that. I'm dropping into the high 40s to around 50 on the low side and I have 38% fuel lobe and that's on about 15 lbs of boost. I'm going to try to make about 18 lbs and if I have to we can turn up the meth/water and I'll hook up the other nozzle if I have to for the LS Fest. We have the Meth/water turned way down so we can add some more fuel to it with just a turn of the dial .
Old 08-14-2019, 07:55 PM   #21
Joshinator99
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
What’s happening to your rail pressure when your low side drops into the 40’s? That would make me nervous as hell...
Old 08-14-2019, 10:37 PM   #22
Drsagacity
Drsagacity's Avatar
Are you running an aux fuel system or a voltage booster?
776whp/745wtq (12psi)
2018 Corvette Z06 vert- Black
To be tuned by JRE Racing
TBD performance
Old 08-15-2019, 12:57 AM   #23
oldman
Drives: SS 6 speed of course
Word. Max hp speculation based on on fuel supply should be uncorrected....
Old 08-15-2019, 06:20 AM   #24
laynlo15
laynlo15's Avatar
2900 PSI at the fuel rail and yes I have a boost a pump but not sure its works as well as JRE's.
Old 08-15-2019, 06:23 AM   #25
wnta1ss
Drives: 2017 Camaro 1SS
parish8 and yourself are on the right track as far as I'm concerned. That car did not actually make 950 rwhp, that's just a dyno number inflated to some degree from the altitude (correction factor). I found a picture of the dyno plots in this test and it says 'STD' which further inflates the numbers. The correction factors were hidden and also the atmospheric conditions were hidden on the plot that I found. Seems that dyno shop is in Las Vegas NV, so it's probably over 2000' actual altitude. Obviously DA at the time of the run would be nice to know.
Old 08-19-2019, 03:20 PM   #26
Choda
Drives: Turbo 6.2
either way... the camaro destroyed the mustang and challenger.
2016 Turbo Camaro SS - 800hp/900tq 9.7@146
2018 LTZ Z71 Redline Silverado - 381hp/420tq 13.8@100
Choda is offline   Reply With Quote
Old 08-19-2019, 07:29 PM   #27
oldman
Challenger is just way too heavy. A really nice street car BTW...I had a supercharged Challenger.
