12-12-2016, 07:28 PM | #1 |
Drives: 2017 1SS/1LE Join Date: Sep 2016
O2 and Evap Not Ready
So, I've had my car for a couple of weeks, but I've been out of town. So, I've only gotten to drive her almost 400 miles. In CA, if you purchase a car from out of state, you still have to smog the vehicle. I tried doing that today, but my O2 and Evap systems are still not showing as ready. I tried doing everything, including following the directions in the link below, but both systems are still not showing ready... I've driven for 394 miles and more than a dozen cycles / cold starts...
Any suggestions? I only have two more days left on my temp tags... http://www.camaro5.com/forums/showpo...47&postcount=8 |
12-12-2016, 07:44 PM | #2 |
#becauseracecar
Drives: 2016 SS Sedan, 2016 Camaro SS Join Date: May 2015
Was it fully heated up before you had them test?
12-12-2016, 07:50 PM | #3 |
12-12-2016, 10:12 PM | #4 |
Drives: NGM '16 2LT A8 Join Date: Feb 2014
You should still pass smog if evap isn't ready, all you need to take care of is the O2 driving monitor.
GM uses a two-part HEGO monitor. The first part of the HEGO monitor runs after idling the engine for two and a half minutes with the A/C and rear defroster on. This checks the O2 heater circuit. After this, turn the A/C and defroster off, then accelerate at half throttle to 55 mph and hold at a steady 55 mph for three minutes. This will complete the second half of the HEGO monitor that checks the responsiveness of the O2 sensors. You could try this for the evap though.There are two-parts to this test. The first part runs after idling for five minutes, then driving at 30 to 45 mph for two minutes (fuel tank must be half to 85 percent full). The second part runs after the vehicle has sit for 8 or more hours (cold soak) without being driven. Start the engine and idle for four minutes, then drive in stop-and-go traffic for five minutes using smooth accelerations and decelerations. Stop and idle for 4 minutes. The EVAP monitor should be complete. |
12-12-2016, 11:48 PM | #5 | |
I just did this (after the car sat for 4 hours) and it's still not showing ready. I'm now at 410 miles. |
12-13-2016, 02:51 AM | #6 |
Yes, IIRC, it should be a cold start and the 2 sequences do not have to be simultaneous
I dont think 4 hours was long enough. It must sit for at about eight hours, in an environment that is less than 90° F. The engine temperature needs to match the air temperature in order to establish an accurate baseline for the testing. If the outside temp is over 90° F, the fuel is too volatile and the EVAP system won't even try to run its drive cycle monitors. |
12-13-2016, 02:54 AM | #7 |
Also you can not have the check engine light on. Even pending ones which will not show the light
12-13-2016, 12:05 PM | #8 | |
12-13-2016, 12:27 PM | #9 |
Drives: 2019 Dodge Challenger Scat Pack Join Date: Jun 2016
How much does it cost to just take the car in and have it smogged checked? I guess I would just take it in and let them tell you whether you passed or not.
"Submariners are a bunch of intelligent misfits that somehow seem to get along, understand each other and work well together." - overheard from a surface officer explaining to another sailor about Submariners
12-13-2016, 12:33 PM | #10 |
To have the actual process documented, I believe it's $20 if it fails (also gets documented on the Carfax, etc.). However, I can verify myself with my handheld scanner if it will or won't pass. So, no point in driving over there to have them tell me the same thing...
12-13-2016, 01:02 PM | #11 | |
To add to this, it looks like you have a BRAND NEW car. If the car "meets CA emissions" then it should be fine and get it checked or take it to the dealer and have them check it (under warranty).
12-13-2016, 02:30 PM | #12 | |
Yes, it may be a brand new car, but the emissions system still has to be fully functional before it'll pass CA smog (a requirement, since I purchased the car out of state). As far as the dealer comment, it's not a warranty issue. The only thing that the dealer will tell me is to "drive the car more..." |
12-13-2016, 02:57 PM | #13 | |
Good luck. It looks like you have all the answers.
12-13-2016, 04:25 PM | #14 |
Drives: ZL1 1LE Join Date: Oct 2016
For CA, this particular dealers experiences show that out of state vehicles won't (or at least, sometimes don't) pass CA smog when they are straight off the train and that in their experiences these systems "click" over at about 500 miles. So that is where I'm guessing he is getting the "just drive more comment".
