Old 06-24-2019, 12:32 PM   #183
2SSRedline
Drives: '18 Camaro SS Redline, '20 Bolt EV
I received and installed my new TB (2018 SS M6) on Saturday and did the relearn Sunday morning.
Both installation and relearn were very easy. The driveability improvement is fantastic, so much more consistent and fluid. Being in stop and go traffic is no longer aggravating.
Why can't they build them this way?
Thanks to Mike and his crew.
John
2SSRedline is offline   Reply With Quote
Old 06-24-2019, 12:42 PM   #184
lgarrison34
lgarrison34's Avatar
Drives: 2017 SS 1LE HBM, 2010 SS FBO/Cam
Installed mine yesterday. Drives like a dream and relearned the mapping quickly after having the battery disconnected overnight. I have a Pray ported OEM IM sitting in the box ready to install next.
lgarrison34 is offline   Reply With Quote
Old 06-24-2019, 12:56 PM   #185
ssmike
BL1ZZRD
ssmike's Avatar
Drives: '16 Camaro 2SS, '20 Equinox Redline
My biggest concern would be how the ecm will adjust over time. I hope that it doesn’t “dumb down” the initial affect of disconnecting the battery and a fresh TB install. Soler can you comment on how the ecm adjusts over time?
ssmike is offline   Reply With Quote
Old 06-24-2019, 01:00 PM   #186
enzia35
Drives: '16 Garnet Red 1SS
I’ve read a few comments about how that happens eventually.
'16 Camaro 1SS
'18 Miata GT
Old 06-24-2019, 01:15 PM   #187
Spanky1
Drives: 2017 2SS Summit White Camaro M6
Does anyone have a pic or the correct steps to remove the connector without losing or breaking it?
Spanky1 is offline   Reply With Quote
Old 06-24-2019, 01:27 PM   #188
grampa_ss
grampa_ss's Avatar
John
Can you (or anyone) tell us what the relearn procedure is?
thank you
Old 06-24-2019, 01:40 PM   #189
Mike@SolerPerformanceLLC
Mike@SolerPerformanceLLC's Avatar
Drives: 2015 Corvette Stingray
My biggest concern would be how the ecm will adjust over time. I hope that it doesn’t “dumb down” the initial effect of disconnecting the battery and a fresh TB install. Soler can you comment on how the ecm adjusts over time?
To the contrary, it gets better with driving cycles until it is fully learned. There is no long term data, these have been out for no longer than 6 months. It is not reasonable to think that it will change any further in any direction after that unless it gets clogged by dirt.
The pedal map is static, for X pedal you get Y throttle, and for Y throttle you get Z airflow, Y to Z is fixed too by the TB geometry. So, everything is fixed from X to Z.
Now you get that extra Z air and the oxygen sensor will adjust fuel trims so it burns stoichiometric (unless enrichment is purposely requested). No problems with fuel either.
That Z extra air + extra fuel = extra power and torque, the ECM will look at torque limits and if exceeded it will reduce spark timing advance, but b/c we are not exceeding those limits timing is not reduced. If it does you'll get small surges in power/rpm's when restored to normal.
I believe, someone at corvette forum said it went backward 20% and that only 80% of the benefit remained.
There is no data to support that, it is an opinion and we respect it. I'll not enter in a philosophical/psychological argument, but it is very easy to get used to a good thing, and we'll gladly take the 80% as a huge win.
Thanks,
Mike@SolerPerformanceLLC is offline   Reply With Quote
Old 06-24-2019, 01:45 PM   #190
thank you
Attached, reading the red font is sort of a summary.
File Type: pdf Relearn and Test Instructions Rev NEW V5.pdf (32.9 KB, 256 views)
Old 06-24-2019, 01:51 PM   #191
Please, see post #161, link below. Watch that video. Courtesy of Trochoidal and Lethal Camaro. We are in the process of rewriting our instructions for this connector as well.
https://www.camaro6.com/forums/showp...&postcount=161
Thanks,
Old 06-24-2019, 02:04 PM   #192
grampa_ss
grampa_ss's Avatar
Thank you sir!
Old 06-24-2019, 02:11 PM   #193
Spanky1
Thanks for your quick response Mike!
Old 06-24-2019, 03:29 PM   #194
DougCBJ
Drives: 2016 Blue 2SS
quick question on the core refund. Is shipping paid for both ways, or will i need to pay shipping to send back the core?
DougCBJ is offline   Reply With Quote
Old 06-24-2019, 05:59 PM   #195
Warrior102
Warrior102's Avatar
Drives: 2018 2SS 1LE Black
I need to stay off these forums (car, motorcycle) they cost me money... Being OCD and already rocking a Tony Mamo I dug out my OEM piece and am sending it in for modification, my OEM TB has less than 4K miles on it. I'm pretty pleased with the TM unit so we'll see I guess.
Warrior102 is offline   Reply With Quote
Old 06-24-2019, 06:26 PM   #196
Mosaic6SS
Drives: Camaro
Hey Mike I thought the new style ECM algorithm adjusted according to driver input. For example if you drive your car more aggressively then the throttle progressivity would adjust and give you a more responsive throttle. On the other hand a new setting from the factory gives a dead throttle feel to aid in vehicle breakin. This throttle lag would also appear if you drive very conservative over a long period of time. I am not sure about track mode but since I have reset the settings and did the throttle relearn and did quite a few hard pulls the throttle in sport setting feels snappy.
Mosaic6SS is offline   Reply With Quote
