04-03-2019, 06:06 PM | #1 |
Drives: 2016 2ss Join Date: Jun 2016
Weight in the trunk
Has anyone played around with adding weight in the trunk for better traction? If so how much?
2016 Black Camaro 2SS A8 Red interior
Modifications:Red powder coated Whipple LT1 blower, Aeroforce interceptor w/vent pod, FI Interchiller, Roto-Fab breather, ARH full length headers with high flow cats, JRE AFM modules, Borla S type NPP exhaust, Mishimoto catch can, JMS fuel pump voltage booster,MRR 017 1LE replica rims, 285/35zr20 Goodyear Eagle F1 G:2 front, Toyo r888r 325/30/zr20 back, Phastek blackout kit for the reflectors, GM dark tail lamps, Blendmount radar detector mount with Escort Redline hardwired in. |
04-04-2019, 06:20 PM | #2 |
Drives: 2016 camaro ss Join Date: Dec 2018
I use to put 2 60lb sandbags in the trunk of my mustang, worked great in the street , but I stilled only weight 2840lb with bags
04-05-2019, 12:24 AM | #3 |
Tactical Garage
Drives: 2016 Camaro 2SS Join Date: Nov 2016
When I first installed the whipple i put a 60lb sandbag in the trunk to help with traction and weight transfer. If you can hook without it you will be faster but if you are not hooking give it a try.
04-05-2019, 04:22 AM | #4 |
Drives: 2015 Mustang GT. Supercharged. Join Date: Jul 2014
Never ad weight to the car. Your just slowing your self down. Increase traction with tires and suspension. Not weight.
04-05-2019, 07:52 AM | #5 |
Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
IF you were looking to add weight to the rear, I'd start by having the fuel tank full rather than showing up to the track at 1/4 full. Either way, adding weight doesn't sound like the right solution
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph |
04-05-2019, 07:30 PM | #6 |
What are some other options? Everyone always says suspension but I can't find anything specific... Used to a 4 link would help but the axel twist isn't bad in our cars to begin with.
04-05-2019, 09:18 PM | #7 |
Drives: 2018 SS 1LE Join Date: May 2018
First thing is are you on a tire?
Also do you have mag ride where you can launch in Touring mode for weight transfer?
🌽 Sauced, 2018 SS 1LE - 123mph @ 5,000 DA
ARH 2”x3” FULL System, Pray Ported MSD Intake Manifold, Pray Ported GM 95mm TB, RotoFab CAI, DsX e85 Kit, MightyMouse Catch Can, NicD Tune https://instagram.com/corn_sauced?ut...d=o0ako89uurwl |
04-05-2019, 09:55 PM | #8 |
Who Needs to KNOW?
Fill up the tank.. plenty of weight.. 17 gal x 6.5 lbs = 110 lbs.
ing for grip.
07-11-2019, 09:51 AM | #9 |
Drives: 17 SS a8 Join Date: Feb 2010
I know some crazy fast street car guys that add hundreds of lbs to their car in the back. I think weight at the rear bumper will do more for you than weight where the gas tank is.
I have never tried it but i am thinking about it.
best et 5.83@121 with the 5.3 http://www.camaro6.com/forums/showthread.php?t=465472 |
