03-06-2018, 03:14 PM | #29 | |
Race what you brung, Hope you brung enough
2016 2SS, NPP, Adrenaline Red Leather and Pads, 6sp, Sunroof, Black Bowties, Upgraded Wheels, 15% Tint, Kooks Headers, MBRP Exhaust, 1LE Wheels, Badging, Ported Throttle Body, Procharged, Snow Performance Stage 2 Meth Kit Coming Soon: Custom Cam, E85, Ported Heads |
03-06-2018, 05:19 PM | #30 |
The basic LT1 kits from NX and Nitrous Outlet tap into the factory fuel supply which is probably what the tuner means by no extra. Such a setup depends on the stock low-pressure pump and there's only so much extra demand you could reasonably expect to put on it before you'd need to upgrade the pump. The NX instructions say to upgrade the pump if you want to use over a 100 shot, for example.
03-06-2018, 07:07 PM | #31 | |
BAMF SS
Your engine makes without spray (say by adding bolt ons, cam, heads etc), the more volume it needs to the injectors to maintain what is referred to as "stoich" or in laymen's terms, your ideal AFR. So the more fuel your engine takes up, the less is available for, let's say a nitrous setup, because your fuel system can only put out so much. Even though it's a pretty safe bet on a stock or bolt on car, any decent shop should check your fuel pressure while they are setting up your nitrous. That and reading your spark plugs, to make sure the timing is right. All of that should be included in your "tune." If they aren't doing that, I would steer clear.
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock 800 SAE rwhp. 9.4 @ 145 mph. |
03-07-2018, 12:10 AM | #32 | |
Drives: 2019 Camaro 1LE Shock Candy Join Date: Mar 2016
It’s your car and go the route that makes you happy.
103 Katech TB, KATECH Custom Heads, DSX In-line fuel TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane. 2014 Mini Cooper countryman S All4 M6 daily driver |
