Old 03-18-2017, 10:38 PM   #15
11bravoss
Drives: 2018 ZL1
Originally Posted by dynosteve View Post
Need some more information to answer the question properly, firstly auto or manual? secondary there was no boost logged on the dyno run what psi were you running?
M6 and pulls were in 4t . Both the baro breakout and my gauge were holding 8psi
11bravoss is offline   Reply With Quote
Old 03-18-2017, 10:54 PM   #16
SC88
Twin Turbo
SC88's Avatar
Drives: 2016 2SS
Do you have the capabilities of taking the car to another dyno to compare? Ive owned cars that have made 80hp less on a mustang dyno vs others.
From what I can tell on your graph your @ 460/440 wp?? The numbers are cutoff.
Boost, Boost & More Boost
Instagram = BoostedSS
SC88 is offline   Reply With Quote
Old 03-19-2017, 07:32 AM   #17
DFW1LE
DFW1LE's Avatar
Did you turn off the nannies?
Old 03-19-2017, 08:25 AM   #18
11bravoss
Drives: 2018 ZL1
Nannies? I know he had the TC disabled while he was tuning it
Old 03-19-2017, 11:04 AM   #19
Atomic Ed
Drives: 2001 Audi TT, 2016 Camaro
There has been some confusion on disabling the TC. Even with the standard TC disabling, there are still some protections in play. The only way to get everything turned off is to press and hold the TC button for roughly 10 seconds in track mode.
Atomic Ed is offline   Reply With Quote
Old 03-19-2017, 11:22 AM   #20
11bravoss
Drives: 2018 ZL1
So if that wasn't done could that have been the result of the numbers be that low?
Old 03-19-2017, 12:27 PM   #21
Davis0079
Drives: 2016 1LT V6
I though the traction control was engine management and the stability control used the brake system. It could be the problem, but strapped down on a dyno, I'm not sure if the stable control would even kick in.
Davis0079 is offline   Reply With Quote
Old 03-19-2017, 12:39 PM   #22
Atomic Ed
It could be part of it, but my WAG says there is still something not right.
Old 03-19-2017, 12:49 PM   #23
Atomic Ed
You would think that to be the case, but by turning everything off verses being in comp. mode, here was the result:
But I don't want to distract too much from the OPs issue. This may be a contributor, but not the fundamental issue. I think there is more to it other than settings for the dyno run.
Old 03-19-2017, 03:28 PM   #24
marknagy13
Markoon13
marknagy13's Avatar
Drives: Camaro 2SS
someone correct me if Im wrong but shouldnt he be making pulls in 5th gear? Isnt 5th the 1:1 and 6th is overdrive?
marknagy13 is offline   Reply With Quote
Old 03-19-2017, 03:58 PM   #25
Ian SS
Ian SS's Avatar
Drives: 2016 1SS, 2017 JKU Wrangler
No, 4th is 1:1, 5th and 6th are overdrive.
SLO 1SS - sold
1SS MRC NPP 6MT
2018 Ram Rebel 4x4 5.7
Ian SS is offline   Reply With Quote
Old 03-19-2017, 04:32 PM   #26
11bravoss
Drives: 2018 ZL1
Talking to Erik at ati. Thinking it might be the cam timing or injector timing was not properly done.
Old 03-19-2017, 05:00 PM   #27
BradfordCamaro
SABIO
BradfordCamaro's Avatar
Drives: 2016 CAMARO 1SS
I can imagine the feeling.....
Sorry you didn't get what you were hoping to see.
Best thing to do is follow up with everyone involved, express your concerns and ask for verification of the Tuning / Set-up.
Still have problems by the end of the week, I am sure some of the in-house experts here on Camaro6 will be able to help.
I want you to see 600 too
Old 03-19-2017, 05:49 PM   #28
Hyper SS
Hyper SS's Avatar
Drives: 16 Camaro 2SS
I'm sure you will get this figured out. Once you do you will love driving your car. I am pulling for you here! We all know the true power is there.
Hyper SS is offline   Reply With Quote
