Old 04-05-2016, 08:34 AM   #1
2slo4u
Drives: 2016 Camaro 2SS, NPP, MRC, Nav
Thumbs down Water leak in trunk area
So, I opened my trunk last week only to find that a few magazines were soaking wet and had to be thrown away.
Then, I decided to lift the carpet and I had 1/2 to 3/4 inch standing water in the bottom of the trunk where the amp and fuse relax box are mounted!!!!!
I took the car to my local dealer. They have had it for 1 week now.
They have replaced all of the weatherstripping and they first claimed that pinched weatherstripping behind the taillights was the root cause. However, a second water test revealed it was still not fixed.
The latest problem they discovered is a "few" body seams were leaking that they will need to repair.
I just wanted to let others know in case this is a recurring problem. I will post the final outcome once I get the car back.
2016 Camaro 2SS MRC NPP NAV Black on Jet black
2slo4u is offline   Reply With Quote
Old 04-05-2016, 09:02 AM   #2
JFM-jr
JFM-jr's Avatar
I notice when I open the trunk water runs over the rubber strip and ends up inside the trunk. I hope they fix your issue.
2016 Hyper Blue 2SS A8,NPP,Moonroof
Pray ported factory intake manifold Ported TB
Rotofab
ARH 1 7/8 longtubes hi flow cats AFM deleted E85
11.0@124.9
11.65@118.8 pump gas,stock tune/exhaust
New combo: Pray Performance Heads/cam
MSD intake manifold and Circle D 3C
554/491 on E85 all work & tuning done by Pray
JFM-jr is offline   Reply With Quote
Old 04-05-2016, 10:39 AM   #3
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
Do you have a sunroof, and have you checked the drain hose?
Rock-It Man is online now   Reply With Quote
Old 04-05-2016, 12:12 PM   #4
2016SS
2016SS's Avatar
Drives: 2016 Summit White 2SS
Had the same thing happen on my cobalt SS was the sunroof drain was pinched from a speaker in the back. Easy fix!
2003 Cadillac CTS Sold
2006 Nissan 350Z Sold
2008 Cobalt SS/TC Sold
2016 Camaro 2SS Summit built 3/28/16 delivered
2018 Camaro ZL1 cancelled by GM 😡
2019 Corvette 2lt Z51
2016SS is offline   Reply With Quote
Old 04-05-2016, 11:05 PM   #5
2slo4u
I do have a sunroof. I got the car back today. They claim it ended up not being the body seams but instead it was leaking around the holes in the trunk lid where the spoiler was mounted onto. They siliconed all the areas and water tested it again. I
Where is this drain Hose for the sunroof for future reference?
