03-29-2016, 03:36 PM | #15 |
Drives: '16 2SS Join Date: Oct 2015
Sorry to hear of your issue, I am interested in what the cause was. I am not an electrical engineer, mechanical actually. 9 times out of 10 I came across an electrical issue, it's actually a mechanical failure, such as relay/contactors etc. mechanically failing to properly close or open a circuit. If something were to short circuit, you likely would end up with a blown fuse somewhere. Sounds like there could be a loose connection or faulty switch causing an intermittent closed circuit when it should be open, causing the seat to move. Does it happen more often when changing speeds or directions? It is kind of odd how many seat related issues there have been with Camaros.
Keep us posted and be safe!
Hyper Blue Metallic 2SS w/ 56V, MRC, NPP, Sunroof, Black Bowties, Black Suede Knee Pads
03-29-2016, 05:44 PM | #16 | |
Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
I'd either unplug the seat connector(s) or pull the fuse(s) associated with the driver seat motor and get the issue fixed ASAP, especially if it's repeatable. |
03-29-2016, 06:06 PM | #17 | |
Drives: Blk/Blk 2018 Sierra SLT Join Date: Dec 2006
SOLD: 2SS LS3 M6 - MGW - Dynatech LT's HF Cats - Magnaflow Street CB - ADM Race CAI - Pedders Xa Coilovers - Pfadt Sways
TRADED: 2016 2SS M6 |
03-29-2016, 06:46 PM | #18 | |
Drives: 4 wheels Join Date: Dec 2009
I purchased the car, drove it 4 hours south 12 hours after purchasing the car..When I arrived at my destination I dropped the car of at the local dealer.. Then the next day I had to get my car back to DRIVE BACK home, 4 hours north.. So again.... I ONLY had my Camaro 4 HOURS AWAY from my home where my secondary vehicle was parked. Dealer stated the car was "safe" to drive back as they found a "temporary" solution which involved cancelling the seat movement by activating something else. I took the dealers word and expertise and drove the car back up, AFTER explicitly letting them know why I needed the car back, and if they agreed I could make it back... You REALLY think I would have NOT left the car there and taken a loaner to get this issue fixed, if I had the chance? Think about that then get back to me.. But, just so I know, was this a good enough explanation? |
03-29-2016, 07:10 PM | #19 | |
A little sensitive are we? LOL relax man im just giving you $hit
03-29-2016, 07:43 PM | #20 | |
As far as being on the hook.. The dealer told me they spoke with GM and actually had a GM engineer on the phone with them when they were trying to find the root cause of the problem.. He stated that the engineer gave the OK to use the car as he suspected it to only be a faulty short..... Regardless, I will keep everyone updated as this could be a problem someone else might face.. I simply just don't have time to drive 30 minutes to my "local" dealer right now.. I'll call tomorrow and see what my options are. Other than that... Man do I love this car... Getting into the fit feels awkward in so many ways..... ESPECIALLY when I'm on the highway! CHEERS |
04-01-2016, 09:07 PM | #21 |
GM executive office reached out to me.. Not sure how they got my number, will inform with results..
I was told they want to know everything before I take the car in, and they want the defective pieces to be sent directly to their engineering team ASAP....... Could this be more serious than we thought? |
04-01-2016, 10:26 PM | #22 |
Drives: 2016 Black 2SS Join Date: Feb 2016
This is a very serious issue! We are just glad that nothing bad has happened.
Camaro 2SS
Black/Jet Black A8, NPP, MRC, NAV Low Gloss Black 5 Spoke |
04-02-2016, 06:44 AM | #23 | |
Drives: Coupeless :( Join Date: Jan 2015
The average person would not have kept their composure and thought through remedies on the fly like you did. Many would have ended up off the road or into the back of another car trying to figure out what to do. |
04-02-2016, 11:42 AM | #24 | |
NOW, my question for everyone is this... Considering the issue, should I attempt to request a new car or should they just fix the issue, and be on my way??? My mom mentioned she is a firm believer in there always being a "possible" underlining defect with the car.. I think it could just be some faulty parts that can be swapped out.. Curious to hear your thoughts??? I will say one thing, I expect some sort of collateral from GM due to the situation at home. |
04-02-2016, 11:45 AM | #25 |
Retired from Car mfrs....
You can request a new car, but you won't get it, when you sign the buyers order you are accepting Chevrolet warranty and that states that they get the fix the problem not replace the car somewhere deep in the FinePrint. Just let them get to the bottom of this, fix the car and go have fun.
04-02-2016, 11:48 AM | #26 | |
04-02-2016, 11:59 AM | #27 |
Yup, if car goes longer than a week or two and involves redesign or a parts production change, youll have simple grounds for some compensation, usually your car payment and a loaner......as first step.
04-03-2016, 11:32 AM | #28 |
Drives: 16 Camaro SS Join Date: Jul 2012
How does the seat moves? Up, down, back, forward? Could as simple as the seat memory switch. Go into the infotainment center and turn everything off what has to do with the seats. Memory recall, easy exit function.
Interior: Adrenaline Red. SS/2SS, M6, NPP, Sun Roof, 8" Nav. Black 5 Spoke Wheels.
