Old 04-16-2021, 06:46 AM   #1
pbsinternet1le
pbsinternet1le's Avatar
Drives: 2017 1le current /2015 2ss 1le sold
Did you know?
If you don't touch the throttle pedal at all and release the clutch the computer maintains 1000rpm and will not stall.. great feature to use if you add a cam. Also if the computer detects clutch slip it will shut down the throttle.. learned this from a tuner. From what I was told the Camaro is the only car that does this.
2017 1LE Hyper Blue
pbsinternet1le is offline   Reply With Quote
Old 04-16-2021, 06:49 AM   #2
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
You can slip it a little, but not a lot. Clutch protection was put into the car in part because it's a dual-plate clutch and will overheat quickly if you slip it excessively. Also because of sillybois like this:
Old 04-16-2021, 09:16 AM   #3
pbsinternet1le
Corvettes do not have the feature I am talking about.. only Camaro from what I was told by a very experienced GM tuner.
2017 1LE Hyper Blue
