04-05-2021, 01:22 AM | #1 |
Drives: 2016 Camaro SS Join Date: Jul 2016
stock(exhaust) vs lt2 intake vs procharger vs whipple vs maggi 2300
Even the units are different , you can check the shape of Tq and Whp. Last edited by shinysun; 04-06-2021 at 03:48 AM. |
04-05-2021, 09:07 AM | #2 |
Drives: 2019 Camaro SS 1LE Join Date: Jul 2020
18hp from the lt2 mani is a pretty significant gain...nice
04-05-2021, 09:08 AM | #3 |
Drives: 17 SS a8 Join Date: Feb 2010
Cool. Do you have boost level for each that you can add to the charts? Did all the boosted ones have the same timing up top?
best et 5.83@121 with the 5.3 http://www.camaro6.com/forums/showthread.php?t=465472 |
04-05-2021, 10:56 AM | #4 |
Power curve on the Whipple looks different then mine. Mine was still climbing in power @ 6400rpm.
2016 NFG 1SS A8
04-05-2021, 03:15 PM | #5 |
Also what exact blower was used for each example would be nice to know.
04-05-2021, 08:30 PM | #6 | |
NA stock IM NA LT2 Procharger(not sure which manifold) Magnuson Whipple
2016 NFG 1SS A8
04-06-2021, 12:34 AM | #7 |
Sorry for the possibility to misleading. I should have mentioned the conditions more.
Actually, I posted the graph for checking the difference of hp, tq shapes btw procharger(Centri) and other blowers. The comparison btw Maggie and Whipple is meaningless due to it has different timing and boost level. (19 degree , 0.7 bar meggi 2300 vs whipple 2.9 16 degree , 0.66 bar at the top) while 20 degree , 0.55 bar for procharger P1SC1 with Lt2 intake. The 2 graphs of N/A ,Lt2 intake and a graph procharger with lt2 intake are from the same car. I didn't mean which one is the better. Cheers! |
04-06-2021, 10:46 AM | #8 |
Much as I like to see the Maggie perform that well, it's indeed an unfair comparison with the Whipple when timings and boost are so different. If you post a graph like this without proper annotations, people will immediately draw premature conclusions.
04-06-2021, 11:09 AM | #9 | |
Yeah but I still like the data and he is giving us the requested info. That being said my 5.3 at similar boost level picked up 21hp going from 16-18deg. Probably would have been 25hp at 19deg. And then add 4kpa which is likely 20 more hp. I would say there is another 40+hp in the whipple if timing and boost were matched.
