02-06-2021, 09:22 PM | #1 |
Drives: 2018 Camaro RS V6 Convertible Join Date: Jun 2018
Rear corner of top popping loose
Recently I started getting a top not secure message, after a lot of poking around I can see its the passenger side rear becoming unlatched. When this happens I can see just a little bit of daylight come through between the top and the tonneau cover. I can also just move that section of the top a little bit by hand.
I can hit the button to close it again and it will close fully, but say I hit a speed bump or sometimes just come back to the car 10 mins later and it will pop loose again. Has anyone else experienced this or know what I could adjust? Its out of warranty and I don't want to take it in right now since cash is kind of tight plus the whole covid thing makes it a PITA to drop and car off with my dealer. |
05-01-2021, 02:59 PM | #2 |
Ok mods can close if they want. Posting the solution in case someone else has a similar issue.
A 10 cent clip was missing which was letting a pin slide out from the end of the hydraulic cylinder, and that pin would get caught on a surrounding piece of hardware. I had to pop off some interior trim to find it. I'm pretty sure even that simple fix would have been expensive at the dealership. If anyone cares I can add a few pics. |
05-01-2021, 09:55 PM | #3 |
The Wicked Jester
Drives: 2020 Camaro 2SS Orange Crush Vert Join Date: Sep 2012
Thanks for sharing. A pic of the before poroblema nd the after solution would be awesome. Its always good to be able to find the solution on your own!
New Car (His): 2020 Camaro Orange Crush Convertible 2SS
New Car (Hers): 2020 Camaro Satin Steel Metallic Convertible 2LT/RS Redline Package Old Car: 2014 Camaro Summit White 2SS/RS Old Car: 2010 Camaro Inferno Orange 2LT/RS |
05-01-2021, 10:03 PM | #4 |
Drives: 2016 2SS BLK A8 Vert Join Date: Dec 2017
Please share pics for reference
05-02-2021, 01:48 AM | #5 |
Ok here are three pics.
A= This is the good side with factory clip in place B= This is the one missing a clip and partially slid out, I first saw it caught on something with the top closed but don’t have a pic C= All fixed but you can see scratches where it was getting caught against the mech. Pulling the top of the interior panels wasn’t that bad, so exploring the system paid off, whole job took like 20 mins and that included looking for a clip that would fit and a tool or two. Hope this helps someone someday |
05-07-2021, 12:29 PM | #6 |
Drives: 1931 Ford 1941&1963 Chevy. 2020 LT1 Join Date: Aug 2020
Thanks for sharing, did you have the clip at your house?
05-07-2021, 10:26 PM | #7 |
I had a variety pack of e-clips and found one that fit, bought he pack years ago for occasions like this. It’s not the same as the factory clip but doubt it can do any worse
05-09-2021, 09:32 AM | #8 |
Drives: 19 ZR1 20 350R Wife -> 24 ZL1 Vert Join Date: Nov 2016
Good to know.
Got a part number? I’ll throw some of them in the trunk. D. |
05-09-2021, 11:27 PM | #9 |
No part number, I think I picked up the variety pack at Harbor Freight years ago
