02-05-2021, 09:50 AM | #15 | |
Drives: 2019 2SS Camaro Join Date: Apr 2012
Im not an oil expert and Im not saying that was what caused the problem, but Im thinking if I had a better oil it might have helped. I do know their is a rating called high temp high shear, and its very low for gas saving with a 0w40 oil and about a point higher for the 15w50. So it uses more gas. Harder on the oil pump I suppose by the same token. I think the same for the 5w50. I never drive the car when its 30 degrees out. So i was thinking that it might have lived if their was more strength in the oil film barrier or what ever. Parts got together on number 8 for sure. I think that's what the castro edge is about, but like many no listing of hths rateing. |
02-05-2021, 03:10 PM | #16 |
Drives: 2019 ZL-1 Join Date: Feb 2009
With a boosted application I would want that oil up to at least 160 before reefing on the throttle. Not warming up an engine with that much power is a good way to spin a bearing.
2012 Yukon XL Denali w/ 6.2 AWD |
03-13-2021, 02:51 PM | #17 |
Drives: 10 LS3 2SSRS IOM,21 ZLE Wild Cherry Join Date: Aug 2009
True, especially for a cammed car. For what it's worth..... when I did my 650 package on my 2010SS at Lingenfelter, the 3 year warranty was void if I didn't use Mobil 1 15w-50. I never left it out in the cold - always garaged and not started from subzero temps. Yes, the higher zinc level over a super long period can lead to Cat failure - but I would much rather replace cats after 10 years (if you're running them), than shorten the life of my engine. My 2021 ZLE requires the Mobil 1 15W-50 for track use and after my engine break-in period I plan on running the 15W-50 year round for the same reason and uses. Yes, the Cats might not last as long and Yes, it's not as fuel efficient - but if I bought these cars for fuel efficiency, I purchased the wrong car!
LPE 650+,IOM Pearl White Rallys
860 RWHP 924 RWTQ,TVS2300 10/14 OD 2.75/NW 102mm,RDS/FLOWED "109" SHOT/LPE NCC NLP spoiler/GM splitter/Torq HE-fans/oil coolers/IC1000cc Squash twins,GT9,Coil Covers,Mats,Pedals/ADM Gauges,Race Scoop/Trunions DDS CVs,Carbon F DS/RPM L6/LPE 9.5 3.73/Pedders HD bushes,align kit RB 2-piece rotors,S/S Lines,Hawk HPE Pads/Forgeline SP3P/Weld RTS Ceramic ARH 2" LT/3" X-pipe,Corsa Touring/BMR TA,Toe,LCA,DS Loop StreetSlayer BC3/MTI Shifter-Trans mt/Hotchkis CB/Monster CC/SJM LineLock PFADT Coil Overs,Sways,Links,Mounts,SF Bushes,Camber Kit LPE Brotherhood . |
03-13-2021, 04:21 PM | #18 |
Oil has to be one of the most popular topics here, and I'm in the majority using Mobil 1 ESP Full Synthetic 0W-40 (as does my Chevy dealer)
'20 ZL1 1LE A10,
03-13-2021, 08:12 PM | #19 | |
03-14-2021, 12:23 PM | #20 |
Someone will correct me if I'm wrong; but according to the current owners manual, 15w50 is only recommended for the ZL1 1LE during track use because the care offers greater lateral grip with it's R-Compound tires and added aero. BK |
03-14-2021, 01:08 PM | #21 |
Only the ZLE
Correct... Only for the ZR! and ZLE due to higher g-forces. And it has to be swapped back out after the track days. |
03-14-2021, 01:18 PM | #22 |
Drives: 2020 Zl1 A10 Riverside Blue Join Date: Mar 2020
03-14-2021, 01:20 PM | #23 | |
Here are the details from the top.. https://www.camaro6.com/forums/showt...php?p=10270970 |
03-14-2021, 01:30 PM | #24 | |
Is so can you drive home from the track on 15W50 let's say 3hrs? |
03-14-2021, 03:28 PM | #25 | |
aka BeastZL1
Drives: 2019 Camaro ZL1 1LE, 2004 Cobra Join Date: Dec 2017
Mlee,
This appears to have changed in 2020. The 2020 High Performance Owner's Manual Supplement doesn't mention 15W-50 any longer and makes no distinction for the ZL1 1LE. (edit: I was wrong. See below) https://my.chevrolet.com/content/dam...supplement.pdf Quote:
03-14-2021, 04:15 PM | #26 | |
03-14-2021, 04:44 PM | #27 |
aka BeastZL1
My bad. You are correct.
03-14-2021, 04:47 PM | #28 |
So are the consensus that a zl1 that using 1le tires and wheels have to use 15W50?
