01-10-2021, 10:53 AM | #1 |
Former GM Technician
Drives: 2018 ZL1 A10, 06 Silverado Duramax Join Date: Sep 2009
Fuel line, check valve question
I plan to replace the factory check valve with the one from Lingenfelter. If I cut the crimped, braided hose from the hardline, is is it possible to use a quick connect fitting on the hardline? Is there already a bulge on the hardline that accepts a quick connect female fitting?
2018 Camaro ZL1 A10
Rotofab Big Gulp, Nick Williams 103, Magnuson 2650, 9.17" (14%) lower, 90mm upper, Vengeance Racing Heads (LME) Cam Package (Cammotion Stage 1), Johnson Lifters, JMS Voltage Booster, Lingenfelter high flow check valve, BBK shorty headers, Custom 2.75" down pipes, Gesi Gen2 high flow cats, MM catch can 791whp, 772ft-lbs SAE Just added 30% XDI Injectors, LPE big bore hpfp, Flex fuel. Elite tuning, results coming soon. 2006 Silverado Duramax Diesel MPI Compound Turbo 40% over Injectors Efi Live DSP5 Tuning Follow me on Instagram: Swisstyphoon1980 |
04-18-2021, 04:47 PM | #2 |
Drives: '17 ZL1 Join Date: Jul 2016
Did you find an answer on this? I have the same question.
04-18-2021, 05:25 PM | #3 |
Yes, there is a bulge on the hardline, but it is not safe with just a new hose clamp, and to short for a quick connect. I ended up cutting the hardline and making a new quick connect flare with a flaring tool.
Or you could also just use a AN hardline adapter like this one. (No flare tool needed) https://www.summitracing.com/parts/EAR-AT165086ERL
2018 Camaro ZL1 A10
04-18-2021, 08:16 PM | #4 |
Awesome! Thank you for the detailed response!
11-21-2021, 12:38 PM | #5 |
Petro-sexual
Could anyone share part numbers for this conversion? Did it work for you guys?
Thanks.
11-21-2021, 02:14 PM | #6 | |
I only have the part number from my link in my post above. & I used some of those AN quick connect adapters https://www.summitracing.com/search/...-quick-connect
2018 Camaro ZL1 A10
11-22-2021, 07:43 AM | #7 |
Petro-sexual
Thank you very much!!!
11-22-2021, 03:25 PM | #8 | |
https://www.amazon.com/MASTERCOOL-72...s%2C431&sr=8-1
11-23-2021, 12:12 AM | #9 | |
2018 Camaro ZL1 A10
11-23-2021, 09:06 AM | #10 |
Petro-sexual
So the line and fittings are 3/8"? I thought someone said somewhere it was 5/16". I think that's part of my confusion. What size is on the car? Being a possible failure point (pointed out in another thread), I'm giving this option a little more though. I could be completely wrong on this one.
Thanks for any more information.
11-24-2021, 02:01 PM | #11 | |
Drives: 2017 Chevrolet Camaro ZL1 M6 Join Date: Jul 2020
JRE Terminator Rough Idle Cam
Magnuson 2650 - 15% lower, 90mm upper FIC+30% DSX Flex fuel/Low side NW 103mm TB/Roto-Fab CAI Monster S Series Elite E2-X 2" TSP LT's BMR:BK063, BK060,TCA061, UTCA060, UTCA063 Weld Beadlocks/17" NT5R2 |
11-24-2021, 02:11 PM | #12 |
Drives: 2017 ZL1 Join Date: Jan 2017
One thing I don't see mentioned in this thread is where whp wise this check valve is actually a concern/restriction... I see 3400-3700 psi (with 70-74 psi feeding it) WOT on my fuel rail pressure during pulls so I haven't found it yet.
I know there are many of us in the 700-900 whp range w/o touching this. Seems easy enough to change but to what value?
