11-06-2019, 04:26 AM | #1 |
Drives: 22 Convertible V8 LT1 Join Date: Feb 2019
Top up/down replacement switch
Hello,
My up/down top switch is failing. Does anyone know the part number? |
11-06-2019, 11:08 PM | #2 |
If I'm not mistaken, the part number is 22774050.
11-17-2019, 10:56 AM | #3 |
Drives: 2017 Camaro 2SS Vert Join Date: Apr 2019
11-26-2019, 12:33 PM | #4 |
Hello, I had a similar issue with my switch. The switch would not engage for Top Up, only down. I carefully twisted the rear view mirror off, popped the clips for the trim off, and was able to gain access to the switch. I disassembled the switch and cleaned the contacts inside the switch. After reassembly it works as I remember it to.
https://www.gmpartsonline.net/oem-pa...witch-22774050 |
11-26-2019, 05:17 PM | #5 |
gmpartsdirect.com
07-05-2020, 11:10 PM | #6 | |
Drives: 2017 Chevrolet Camaro Convertible Join Date: Jun 2019
Do you know if there is a YouTube video showing how to do this?? |
07-07-2020, 08:48 PM | #7 | |
Drives: 2019 2SS Convertible Camaro Join Date: Mar 2012
if you go to gen5diy.com, there is a video for installing the Escort radar detector harness. It tells you how to pop the panel down. Becareful not to take the mirror off, its a pain in the ass to twist back in.
\(^^^)/ <--A Smile From He11
Escort 360 MAXX w/DIYGen5 hardwire Harness K&N AirCharger Cold Air Intake Sound Tube Delete |
10-15-2020, 09:17 AM | #8 |
I am having some issues again with the switch. Might have to replace it if contact cleaning does not help.
04-04-2021, 05:30 PM | #9 |
Drives: 2017 Camaro SS Join Date: Mar 2021
I just had to correct this same issue. Replace switch came in, and the install wasn't as bad as i thought. I couldn't find a install video so i just went out and decided to "wing it". Nonetheless, my top is back working properly.
