Go Back   CAMARO6 > Marketplace > Sponsors Classifieds > V8 Bolt-Ons & Tunes
Old 04-26-2016, 03:56 PM   #1
southerncarparts
southerncarparts's Avatar
Drives: 2009 Corvette Z06
Now available from SCP: 6th Gen Camaro SS Borla ATAK Axle-Back 11921 No dual mode
2016-2017 6th Gen Camaro SS Borla ATAK Axle-back 11921 No dual mode
Borla designs their exhaust products to ease the stranglehold your stock exhaust system has on your vehicle's engine. Borla's patented technology opens the way for escaping gases, and maximum exhaust flow equals improved performance. This translates into more power and torque when you plant your foot, along with increased fuel economy at cruising speeds.
Borla builds its exhaust systems from aircraft-grade T-304 stainless steel, so they're lighter, stronger, and last far longer than factory exhausts - all with easy bolt-on installation. Extensive research determines which tube size will get the most performance from your car or truck. Smooth mandrel bends and efficient design give the exhaust a mellow rumble while keeping most of the sound behind the exhaust tips. This means you won't get unwanted droning noises in the cockpit while cruising. Every Borla exhaust system gives you precision fit with motorsport-inspired styling, all backed by a million-mile warranty against defects in material or workmanship.
This high-performance replacement exhaust system includes all parts and hardware required for installation (some factory original parts may be re-used).
- Rear Section ATAK Dual Exhaust System
- 2.75" into muffer dual 2.5" out
- Will fit vehicles equipped with Dual Mode Exhaust (NPP) but does not include Dual Mode valves
Check it out here: 2016-2017 6th Gen Camaro SS Borla ATAK Axle-back 11921 No dual mode
southerncarparts is offline   Reply With Quote
Old 06-21-2016, 11:41 AM   #2
elpatofeo
LawBraker
elpatofeo's Avatar
Drives: 10 SIM 2LT/RS & 2016 1SS Hyper Blue
In others words, you don't have the different modes to silence the car?
elpatofeo is offline   Reply With Quote
Old 07-20-2016, 08:21 AM   #3
southerncarparts
With this system that's right, it's just a traditional or single-mode exhaust. If you want a Borla ATAK that maintains the stock NPP option, you'll want this one instead:
2016 Camaro SS (NPP) Borla ATAK Axle Back Exhaust 11925
Old 07-10-2017, 08:10 AM   #4
southerncarparts
By the way guys, we have these in stock almost all of the time...this means you get them at the lowest possible price, you get these with free shipping and you get these right away!!
Old 03-18-2018, 09:02 AM   #5
southerncarparts
Old 11-01-2022, 02:03 AM   #6
southerncarparts
Check it out here: 2016 6th Gen Camaro SS Borla ATAK Axle-back 11921 No dual mode
