09-27-2016, 05:10 PM | #15 |
Drives: 2016 Camaro 1LT Join Date: Jan 2016
So when you throw your right turn signal on, does the glow-tie turn off like the rh drl will?
09-28-2016, 10:56 AM | #16 |
Drives: 2016 Hyper Blue Metallic 1SS M6 NPP Join Date: Jan 2016
No. It stays on
2016 Hyper Blue Metallic 1SS M6 with body color hood vents, Silver broken 5 spoke wheels, NPP dual exhaust, Dark Night Interior Spectrum Lighting, Illuminated door sills plates. Upgrades include: Roto-Fab intake, Mishimoto catch can, MBRP cat-back Race exhaust, TSP 1 7/8 headers, EFI E85 Flex Fuel, MRR M017 graphite wheels with Nitto N555 G2 tires, Goodridge stainless steel brake lines, Powder coated Brembo calipers, BMR suspension, Eibach sport springs, Emblempros fender badges Order ID: TDHQMS 1100 on 01/07/2016 at Penske Chevrolet 6000 on 02/23/2016 Delivered to customer |
12-25-2017, 09:11 PM | #17 |
Drives: 2017 F1FTY Camaro 2SS Join Date: Nov 2017
A couple things that helped me with my install that I would add that hasn't really been shown:
to remove the upper fascia support, I had to bend the hood release over as the arrow shows in order to have access underneath https://flic.kr/p/DenwoB After I drilled out the hole behind where the original emblem was, I mounted the glow-tie in its place and routed the cable as shown: https://flic.kr/p/22SMrz6 Instead of removing the whole front bumper, I removed the wheel liner and switched the harness per the install instructions: https://flic.kr/p/22SM3RF https://flic.kr/p/21xm26c Turned out great! https://flic.kr/p/DenghK |
03-17-2018, 10:02 AM | #18 |
@Blackmamba_1LE
Drives: 2017 1LE Join Date: Jun 2017
Thanks guys
OG: Pray Perf FBO ET:11.5 @119 THEN:LT4 SC, E85 + Meth :10.6 @135 NOW: H/C Whipple 416ci
03-17-2018, 09:27 PM | #19 |
Drives: 2017 Camaro 2SS Convertible Join Date: Sep 2017
That black glow tie looks awesome on these black cars. Mine was installed from the dealer before I bought it. I would have done it myself and saved the cash if I had the choice. $395 is a tad high in my opinion but a must have in my book. Loving it.
04-24-2018, 12:43 AM | #20 |
Drives: 2016 Camaro 2SS/RS Join Date: Oct 2008
Just ordered mine and can't wait to get it. Already have the black bowties and only ordered the front black illuminated bowtie for $199 on ebay.
2016 2SS: Silver Ice, A8 Auto, Adrenaline Red, Black Rally Stripes, and Black bowties.
My Journey..... 1100 Status - 08/17/2015 : 2000 Status - 09/28/2015 2500 Status - 09/29/2015 : 3000 Status - 09/29/2015 3000 Status - 10/19/2015 TPW 11/9 3800 Status - 11/04/2015 Seq: 122808 4300 Status - 12/17/2015 (Charlotte, MI) 4200 Status - 01/08/2016 4800 Status - 01/14/2016 5000 Status - 01/19/2016 6000 Status - 01/20/2016 |
10-30-2018, 09:22 PM | #21 | |
Drives: 2017 2SS, 2023 3LT RS, 2011 2LT RS Join Date: Aug 2014
10-31-2018, 07:02 PM | #22 |
2018 Garnet Red ZL1 conve
Drives: 2013 & 2018 ZL1 vert Join Date: May 2009
I wish they had some sort of lighted bow tie for the flow tie. I just added a lighted red bow tie on the back of my 2018 ZL1 vert from Oracle. I have a red lighted bow tie on the front (from RiverCityCreation.com) and rear (from Oracle), they look really nice on my 2013 ZL1 vert. I always get asked where I got these mods if I have the car out at night.
Build Thread: 2018 ZL1 Vert Purchased (Overpar73)
10-31-2018, 09:32 PM | #23 |
Just a few notes for those doing this.. If you have all the tools you can do this in <30 mins easy. You do not have to take the wheel off nor the front bumper.... unless you have huge forearms.
If you remove the upper bumper support, as mentioned you need to bend the hood latch back a bit, its a lot easier. I used a step bit to drill the hole for the new emblem. I noticed it needs more cut off the bottom. Jack up the passenger side tire. Remove the bottom bolt. This is easier if you turn the wheel left. Remove the next three holding in the liner (easier turning the wheel to the right) The clip is connected vertically and plugs into the bottom of the "ballast". The connector has a clip that needs to be pulled down, then the button will release the connector. Since the connector is the same as the one in the new glowtie harness, you can look at the one you're about to plug in as an example. If you leave a light in the fenderwell you can easily see where the harness needs to feed. Hope this helps! |
11-30-2018, 04:59 PM | #24 |
Drives: 2017 Camaro SS Join Date: Nov 2018
Great advice here. I'm not sure if I'll wade into this on my own or have the dealer do it. Thanks.
Kevin
Luceo Non Uro |
01-30-2019, 12:03 AM | #25 |
Drives: 2017 2SS M6 Vert Summit White Join Date: Jul 2018
Thanks for the write up. I installed the illuminated door sills from one of your other write ups. Then I installed the bowtie kind of following what you did. I went from the top after slightly bending the hood latch to get the cover off.
2017 2SS M6 Vert Summit White; aFe CAI, E85, dyno tuned; Bigworm Graphix, various exterior mods
02-02-2019, 06:16 AM | #26 |
Your welcome! Glad people are using these to help them add the upgrades they want to do. If I had to do it again I would have figured a way out not to remove the front bumper cover. I tried going from the top with removing the hood latch but hand would not fit. Take care and enjoy
02-02-2019, 06:42 AM | #27 |
Drives: '17 2SS H50 Join Date: Mar 2016
I looked over this thread as well, when I was looking into the glowtie install. I went through the top. Removed one bolt from the hood latch and loosened the other. Plate came right off. Thanks.
1100 - 5/26 0000 - Cancelled - 7/5 Contacted Becky - 7/1 2000 - 7/5 3000 - 7/6 3000 - 7/11 TPW 8/1 3100 - 7/18 TPW 8/1 3300 - 7/20 3400 - 7/21 Built - 8/2 - PS 1,182/1 of 699US 4300 - 8/3 5000 - 8/5 6000 - 8/13 |
11-01-2020, 10:21 PM | #28 | |
That guy
James Montigny
2017 Camaro 2SS A8 - Krypton Green Magnuson 2650, TSP Head/Cam, DSX Low Side, Flex Fuel, LT4 HPFP, 103mm TB, Big Gulp. |
Thread Tools | |
