05-14-2020, 12:38 AM | #1 |
Drives: 2018 SS, 2016 GT Join Date: Mar 2018
Has anyone run 30 sidewall all around?
I'm looking at new rims and tires for sale,
The tire sizes are 285-30-20 and 315-30-20 I've had 30 sidewall on the front with a 40 sidewall in the back and stabilitrack put me in limp mode every time I drove it. I wonder, considering sidewall is 30 all around if stabilitrack will allow it. Dealer will not reprogram as well as tire shops in town who have the ability to do so won't either because it was unapproved sizes. Thank you guys in advance. |
05-14-2020, 01:36 AM | #2 | |
Drives: 2017 1SS/1LE Join Date: Sep 2016
Also, OEM sizing on ZL1 and SS 1LE is 285/30/20 and 305/30/20. So plenty people are running "30 sidewall all around". |
05-14-2020, 08:51 AM | #3 | |
Drives: 2017 1SS 1LE Join Date: Jun 2016
What do you mean by "won't program them?"
2017 SS 1LE.
05-14-2020, 09:26 AM | #4 | |
Drives: 2019 Camaro Z-28 Join Date: Jul 2010
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 |
05-14-2020, 06:57 PM | #5 |
Ok that's good to hear from all of you.
So the dealer will not program any diameter difference because reasons. As soon as I went back to stock sizes tmps limp mode went away. So I've been more cautious about it . Thank you guys for everything! |
05-15-2020, 08:01 AM | #6 |
Drives: 18 ZL1 nightfall grey A10 Join Date: Apr 2018
I’m running 295/30/20 and 325/30/20 with no issues.
05-15-2020, 09:33 AM | #7 |
I run 245/40/20 27.7" and 305/35/20 28.4" with no issues. You have to keep the front and rear under 1" in height difference. Been this way for 20 years with GM ABS/TCS/Stabilitrak systems.
2016 NFG 1SS A8
05-16-2020, 06:22 PM | #8 |
Thanks again for all your replies.
So whos been running 305+ without relocating the harness? |
05-16-2020, 06:27 PM | #9 |
Given how easy it is to do, I guess the question is: why NOT relocate the harness?
05-17-2020, 11:59 AM | #10 |
Drives: 2017 1SS 1LE...makes me go YeeeHaw! Join Date: Mar 2012
Nice!
Questions: Did you have to relocate the rear harness? What width rims are you using? Are you using spacers up front? Would you be able to go 305 up front with no issues at 20"?
The Thrill isn't around the corner, the Thrill is the corner!
So don't hesitate, just brake late! |
05-18-2020, 12:58 PM | #11 |
2753020 3053020 michelin ps4s here no problems
