04-19-2021, 01:05 AM | #1 |
Drives: '17 2LT/RS 2.0T M6 50th Anniv Vert Join Date: Feb 2019
Rear Reflector Screw Size
Does anyone know the screw size for the OEM Reflector? I checked a couple of GM parts sites and there is no call-out. Also, I stopped by two auto parts stores and I could not find a match.
I need to swap the smoked ones back to the OEM and the phillips head is slightly rounded when I removed it. The screws on the smoked reflectors are a different size than the OEM. |
04-19-2021, 01:55 AM | #2 |
Don't know the exact answer, but I found a bunch of GM-specific bolts and screws at https://www.clipsandfasteners.com/ca...show=45&page=1.
The official name of this screw is "rear fascia lower signal lamp fastener" (yes, they call the reflector a "lower signal lamp" here) in case it helps, there indeed doesn't seem to be a breakout diagram anywhere that would specify it.
04-19-2021, 02:01 PM | #3 |
Thanks arpad_m! That is a good website you shared. There appears to be a couple that are close and I'll measure the screws to see if they are the right ones.
Coincidentally, the shop is about 20 minutes from my office! |
