Old 03-28-2021, 08:36 PM   #1
Daltonluoma118
Drives: 2017 camaro ss
Worth doing axleback exhaust?
I have a 2017 camaro ss with NPP and I’m curious if it is worth upgrading to an aftermarket axle back or catback. Is it really much louder or not really? I’ve seen mixed reviews but don’t want to waste the money if it isn’t a good difference. I may do headers down the road but not anytime soon.
Daltonluoma118 is offline   Reply With Quote
Old 03-28-2021, 09:42 PM   #2
Vaska
Drives: On Hiatus
Yes there is a difference. Lots of info on axle back exhausts, search.
Vaska is offline   Reply With Quote
Old 03-29-2021, 12:43 AM   #3
ThirstyDave
ThirstyDave's Avatar
Drives: 2017 Camaro 2SS 50th Anniversary
It's worth if you want a different sound, tone and want it louder. I went with a Stainless works axle back because I got a great deal and I didn't like the rasp and higher pitched tone with npp and catless headers.
ThirstyDave is offline   Reply With Quote
Old 03-29-2021, 08:26 AM   #4
avalonandl
avalonandl's Avatar
Drives: 2019 ZL-1
You spent $ 900 on NPP and you want to spend another $ 800 to 1200 ????
Old 03-30-2021, 07:44 AM   #5
laynlo15
laynlo15's Avatar
Drives: 2022 Lt1 A10
Its probably not going to improve the performance but sound will be usually louder. Plenty of us have made 850 rwhp with stock cat back Npp. I only had long tubes/xpipe and still made well over 850 and ran 9.40@147 with it so its no very restrictive in my opinion and the performance shows that also.
Old 03-30-2021, 08:12 AM   #6
Chrome383Z
Chrome383Z's Avatar
Drives: 2019 Camaro 2SS
Only reason to change is sound. I was going to get the corsa system but then decided to just keep the $$$ in my pocket.
This fall I’m going FBO E85 with 2” CSP headers and their new high flow cats... plan on keeping the stock NPP at least for the short term. If I don’t like the sound I might consider it but I want to see how it sounds with stock NPP before dropping $2k on a corsa ab...
2019 Shock 2SS A10. 2650@10psi/LPE HPFP/XDI+30/LT4 LPFP+JMS/Soler 95mm/Rotofab, E65, CSP 2” Headers/GESI GenII Cats. MM Wild/GM SG3 suspension/1LE Brakes, Velgen VF5 Wheels/GY SC3. JRE Tuned.
Chrome383Z is offline   Reply With Quote
Old 03-30-2021, 08:55 AM   #7
LT1ornothing
Drives: 2020 LT1 M6
I wouldn't mess with it since it has the npp, if track mode and fuse pull aren't enough for you, look into rear cat delete if your state does not do visual emissions inspections. The rear cat delete should make it louder and deeper. Several forum members happily run that set up.
I on the other hand had no npp on my car, and the axle back prices I saw were outrageous, so I had a muffler delete done and couldn't be happier. Saved a ton of money, got the sound I wanted, and the kicker is the car is 30 lbs lighter.
Old 03-30-2021, 10:35 AM   #8
Vaska
Drives: On Hiatus
A muffler delete (straight pipes) is extremely loud and drones like a mofo, not everyone will be into that. I'd wait for a used axle back to in the classifieds, that's what I did and couldn't be happier on the cost and sound.
Old 03-30-2021, 10:48 AM   #9
Jaxcam02
Jaxcam02's Avatar
Drives: 2017 Silverado/2017 ZL1
No, save your money for engine work or long tubes or something. The money to power ratio increase is tragically ineffective for an axle back exhaust.
Jaxcam02 is offline   Reply With Quote
Old 03-30-2021, 11:09 AM   #10
LT1ornothing
Drives: 2020 LT1 M6
This has not been my experience, only the cold start is loud and after it warms up its hardly louder at idle than with the muffler on. Cruising is also quiet, very easy to have a conversation with a passenger. , it's only loud when I give it throttle. As to drone, I don't notice it, mine is an m6 so maybe your experience was with an automatic. For what it's worth, when the warranty is up, I intend to put the factory muffler back on when I do 2" long tube headers and catless midpipes.
As previously mentioned, I'm sure the OP would be happy with a track+fuse pull and a rear cat delete as so many other members have done, if he can get away with it in his state.
Old 03-30-2021, 11:16 AM   #11
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Borla Atak w/ NPP is plenty loud. Yes, it's a lot louder like piss off the neighbors louder. S-type will also be louder, but not crazy like ATAK. "Waste" is a matter of perspective. Is $3k too much for you?
If you go headers, then keep the stock suitcase, as it'll likely sound better than the Borla+headers.
For me, the stock NPP is fine and any $ spent on exhaust would be a waste: with the top down NPP in track mode it's just right.
Old 03-30-2021, 11:35 AM   #12
enzia35
Drives: '16 Garnet Red 1SS
I thought my ATAK was a great purchase. Headers...eventually.
'16 Camaro 1SS
'18 Miata GT
Old 03-30-2021, 12:28 PM   #13
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
Axle-back for sound/volume, track mode and/or fuse pull was too tame for me personally. The only way IMHO you can get in to it though because some are exorbitantly priced, you go axle back with MBRP or Solo where you can do that for <1K. There's little to no reason at all to go cat back with these cars. Borla and Corsa are clown world expensive for what they are.
Old 03-30-2021, 01:04 PM   #14
LT1ornothing
Drives: 2020 LT1 M6
You ain't kidding man, highway robbery on the corsa and borla. Great sounding but they're not worth their asking price to me.
