Old 03-27-2021, 01:31 PM   #1
beworthy3
beworthy3's Avatar
Drives: 2018 Camaro SS 1LE
Advice needed. Big screw up
Tightening my oil cap with a wrench and this happened. Bolt broke off. Any ideas on how to free the part stuck in the hole?
beworthy3 is offline   Reply With Quote
Old 03-27-2021, 01:36 PM   #2
enzia35
Drives: '16 Garnet Red 1SS
If you’re asking here it’s too much for you. Get to a good mechanic.
'16 Camaro 1SS
'18 Miata GT
Old 03-27-2021, 01:41 PM   #3
KLG
KLG's Avatar
Drives: 2016 2SS Convertible
That is the oil drain plug in the pan that you've broken, I think?
If so, center punch it as close to the center of the broken piece as possible, then use a reverse drill bit to drill a hole into it. Do not use standard drill bit!
With any luck, the broken piece will back right out as you're drilling the hole. If not, you many need to use a broken bolt extractor after you've drilled the hole into the center or the broken piece.
Good luck with it.
--KLG--
2016 2SS Convertible; SIM; Black & Ceramic White interior; M6; NPP; DD LED side marker lamps & back-up lamps; LED trunk lamps, license plate lamps & front T/S lamps; 3rd brake light pulser; Skip-shift eliminator; Borla s-type non-npp axle backs; Weather-Tech floor mats, trunk mat, rear license plate frame/cover; GM fuel door; ZL1addons rock guards; Removed fender badges, front & rear SS badges; JLT CAI, tune, oil separator; RP Synchromax in transmission; RP MaxGear in rear differential; GM Lowering Suspension Upgrade; Dimple oil filter magnets & magnetic oil drain plug; 3M Ceramic window tint.
KLG is offline   Reply With Quote
Old 03-27-2021, 01:45 PM   #4
beworthy3
beworthy3's Avatar
Oh Jesus i got it. That little metal piece that’s sticking off the plug was just big enough for me to spin it out with an Allen key. Huge relief thanks for the help
Old 03-27-2021, 02:21 PM   #5
Invertalon
Drives: 2021 2SS
Glad you got it out.
I am honestly shocked the bolt broke in half before you just destroyed all the threads in the pan, being aluminum and all. The torque is quite low on that bolt (18 ft-lbs I believe), you must have been really going at it or the bolt was defective in some way.
Invertalon is offline   Reply With Quote
Old 03-27-2021, 02:27 PM   #6
beworthy3
beworthy3's Avatar
The threads looks brand new. Honestly wasn’t going at it hard. Never used a gun on it or anything. Maybe defective. Not sure. Just glad that crisis was averted
Old 03-27-2021, 03:15 PM   #7
SHE'Z 18
SHE'Z 18's Avatar
Drives: 18 ZL1 - M6
I'm glad to see that you got it out. I cringed when I saw the picture. Chalk this up to a lucky day.. Now, go buy a lotto ticket. Maybe you're good for two lucky miracles today..
Take care...
SHE'Z 18 is offline   Reply With Quote
Old 03-27-2021, 05:34 PM   #8
gtfoxy
Drives: '21 Wild Cherry ZL1
Never had that happen in hundreds of oiled changes.
Old 03-27-2021, 06:19 PM   #9
pauly1119
pauly1119's Avatar
Drives: 2018 ZLE
Damn thank goodness.
pauly1119 is offline   Reply With Quote
Old 03-29-2021, 06:33 AM   #10
dmcmahan60
dmcmahan60's Avatar
Drives: 2017 SS
Glad you got it out, but you need to get your arm recalibrated LOLZ.
dmcmahan60 is offline   Reply With Quote
Old 03-29-2021, 06:54 AM   #11
FarmerFran
FarmerFran's Avatar
Were you using a torque wrench?
2023 Camaro ZL1 Vert TR-6060 Sharkskin "Sharky"
Firecracker Red Wrangler Willys, 3.6L eTorque, 850RE 8 speed automatic, 25W Willys package, Technology Group, Convenience Group (aka $600 garage door opener), Cold weather Group, Trailer Tow and HD electric group with AUX switches, 3 piece black freedom top.
Old 03-29-2021, 07:02 AM   #12
brap999
brap999's Avatar
Drives: 2018 ZL1 1LE
Same here. of all the cars i've owned in 25 years the ones with drain bolts that were over torqued always end up stripping the threads then leak. I've never seen one actually have a bolt break.
2018 Chevy Camaro ZL1-1LE
2015 Silverado 2500HD
1999 Jeep Cherokee Sport
1998 Dodge Viper GTS
1972 Pontiac GTO
1963 Chevy C10 short bed, T5, 350, lowered
brap999 is offline   Reply With Quote
Old 03-29-2021, 08:13 AM   #13
nancygrl
雪の玉
nancygrl's Avatar
Drives: '22 Z71 RST Silverado
Whew...glad you got it removed....somebody doesn't know their own strength, lol
nancygrl is offline   Reply With Quote
Old 03-29-2021, 11:42 AM   #14
kyle702
Drives: LT1 Ordering
Good job getting it out.
Air impacts and electric drills are for taking bolts OFF. Never use these to put them on unless the owners manual calls for it.
Like others have said, you may have bent the threads. Get a new drain bolt and crush washer check it every day so see if its slightly leaking. If so so you just need a new oil pan, dirt job but very easy if u get the gasket and don't over torque any bolts lol.
kyle702 is offline   Reply With Quote
