02-18-2017, 01:29 PM | #1 |
Drives: 2019 ZL1 1LE Join Date: Feb 2017
Active exhaust?
Only had my 1LE a little over a week but I was wondering how the active exhaust "should" operate.
I've noticed that no matter what mode I have the car in, the exhaust sounds exactly the same, to me anyway. Also noticed that the inner exhaust tips look brand new, absolutely pristine, while the outter ones with the flaps in them are just about black. When the car is off, I see that the flaps in the exhaust tips are in the open position. Once I start the car, the flaps stay open and they never close no matter what mode I have the car in at idle. Is this the way they're supposed to work? Do those flaps close at certain RPM or certain throttle position?
Old: 2017 SS 1LE
Old: 2017 ZL1 Current: 2019 ZL1 1LE |
02-18-2017, 02:49 PM | #2 |
Drives: 2017 Camaro SS 1LE Join Date: Jan 2017
I believe that valve will be open during startup in all modes except stealth. The valve stays closed under a certain rpm in tour mode. Try revving it to 3k or so in tour mode and it should stay quiet. Or do what I do and select what you want it to do under your settings under Engine sound management. Stealth should remain closed at all times. It's possible someone at the dealer has it set under the settings to remain open as well.
02-18-2017, 03:09 PM | #3 |
Drives: 2017 Camaro 1SS 1LE Join Date: Jan 2017
Yeah it sounds like the dealer set the engine sound management setting to track manually. I set mine into track mode permanently immediately after getting home from the dealer and my inner exhaust tips are pristine as well.
02-18-2017, 04:33 PM | #4 |
Drives: ZL1 1LE Join Date: Oct 2016
As others have stated, don't mess with the drive modes, but go in and change the engine sound management settings. There should be a noticeable difference between stealth and track. I generally keep it in stealth for start up and my neighborhood, then switch to track a few blocks away.
02-18-2017, 04:59 PM | #5 | |
This is exactly what I'm looking to do. Don't want to annoy the neighbors too much thanks, I'll check it out.
Old: 2017 SS 1LE
02-18-2017, 05:50 PM | #6 |
You guys were right, someone had set the engine sound management to sport. As soon I set it to auto, I heard the flaps and the exhaust got way, way quieter (I was in tour mode).
Thanks much!
Old: 2017 SS 1LE
02-20-2017, 09:47 AM | #7 |
マスタング = 遅い
Drives: 2017 Chevrolet Camaro SS 1LE Join Date: Aug 2015
I have the fuse pulled on mine, so it's a little louder while cruising now (no partial flap closure) and always open. Still need to make it louder...not enough volume for me. Probably going to do something with the mid pipes soon.
02-20-2017, 09:51 AM | #8 |
"M1SS1LE"
Drives: 2017 SS 1LE Join Date: Dec 2015
Check your vehicle settings - drive mode - Exhaust Sound Management. Make sure its not set to track. If you want it to vary with modes select that option at the top.
MJK3888 Instagram Link
02-20-2017, 09:53 AM | #9 |
Drives: 2017 SS 1LE Join Date: Mar 2016
I love the sound of the stock exhaust with the valves open but like you said it just needs more loud! So I picked up a very lightly used Stainless Works Cat-back (w/NPP) for $1k and will be installing it ASAP! Can't wait for more loud!!!
IG: @NC_M1SS1LE
02-20-2017, 10:05 AM | #10 |
マスタング = 遅い
Yeah, not sure what I wanna do yet. Everyone who hears my car from he outside says it is "loud". I'm guessing the insulation must block some of the volume when inside the car. I'll have to have a buddy of mine do a drive by soon under load.
02-20-2017, 10:37 AM | #11 |
Yep my buddy tells me the same thing, but either way it's still nowhere near as loud as my last car (I had Flowmaster Outlaws in it) so it needs to be louder. And I really love the deep throaty sound of the SW system!
IG: @NC_M1SS1LE
02-20-2017, 11:20 AM | #12 | |
Drives: 2017 1LE Join Date: Jul 2016
Same, I knew I would deviate from the stock NPP eventually. My last car was a 5.0 with what would be the equivalent of an ATAK axleback (roush) and x pipe. When I first had it installed I really thought it was too loud and I was going to have to take it off. The combo I had was louder than many cars with long tubes and axleback haha. How do you like the SW system? I looked at that instead of Borla but then saw one guy said it droned a bit and I ran as fast as I could
17 Summit White SS 1LE PDR / Borla S type Catback / XPEL Ultimate PPF
02-22-2017, 03:31 PM | #13 |
Drives: 17 HBM 1LE Join Date: May 2016
Where do you access the Exhaust Sound Management. I checked under the wheel options and the different modes?
02-22-2017, 03:51 PM | #14 | |
The BEAST
Drives: '16 2SS, '89 Wife Join Date: May 2015
Someone on the forums suggested folding down the back seats to get some more sound inside, and that actually worked to my surprise. It wont be a dramatic difference, but you will notice it.
