12-29-2014, 02:57 PM | #1 |
Drives: 2013 zl1 1969 matching z 28 Join Date: Jul 2013
roll bars in zl1s on texas mile
do most people running the texas mile have roll bars installed, at least 5 point?
12-29-2014, 05:11 PM | #2 |
Drives: 2012 ZL1 Join Date: Sep 2014
From what I'm reading it is not required unless open top or convertible.
12-29-2014, 05:47 PM | #3 |
Speed Freak
Drives: 2013 ZL1 Camaro, 2016 Camaro SS Join Date: Jun 2013
When your car goes through tech inspection it gets approved for a max speed. If you do not have a roll bar your max speed is 199 mph. It is kind of a drag because if your car is tech inspection limited to 199 and you go 201, they will not give you the time slip. So even though you know you went 200 you don't get the certificate. Same if you run outside of a speed you are individually licensed to go. My current license is only good to 220 mph, If I made a run faster than that I would not receive a copy of the time slip and would get a minor scolding about running outside my license limits.
So if you have any possibility of going 200 mph you should get a cage in the car. If you are fairly certain your car will not make 200 mph then don't worry about it. The conditions and the wind would have to be just about perfect for a blower only car to go 200mph without nitrous. I'm not 100% certain but I don't think it has ever been done... well except Snappy with his 4.2 liter Kenne Bell blower on a no nitrous shakedown pass.... and even then he is close to 1000 whp.
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date. |
12-29-2014, 07:53 PM | #4 |
I've been doing some reading on their website, but there is a lot of information to go through. Basically you start with a license for under 165mph then you make a pass and as long as you go over 140 and under 165 you can move up to 199? I don't see my stock ZL1 coming close to that I just plan on going to see the event and have some fun getting to a high speed without risking my CDL.
12-29-2014, 09:09 PM | #5 |
camarolover2
hey jess, with the 750 package on my car and good tires that will hook up what is your best guestimate of my terminal speed. about 700 rwhp on 91 octane, and 750 at 110 with 3.73 rear end gears
12-30-2014, 10:31 AM | #6 | |
Speed Freak
The wind makes a huge difference with the amount of drag Camaros are pulling at speed and unlike the AWD cars we are not running out of gear. If the wind conditions are bad you may only get 175, if they are perfect you may get 195. If you put a spacer behind the throttle body and give it a 100 shot it will be able to do 200 in even fair conditions.... just not bad. My first time out was the year almost no records were broken because we had constant headwind the whole weekend. I had 4 passes in the 190's couldn't break 200.
12-30-2014, 10:35 AM | #7 |
Drives: Camaro Join Date: Mar 2013
Andy at ADM calculated mine would do 185-190 with his 750 package and 3.73 gears and M6.
12-30-2014, 10:51 AM | #8 |
Speed Freak
That is probably what it would run if you got your car in line at 4 AM so you had cool morning air and if it happened to be the kind of day where the morning air was dead flat with no wind at all and then you hit all your shifts perfectly at the limiter......
12-30-2014, 11:08 AM | #9 |
Agreed, perfect conditions.
12-30-2014, 02:04 PM | #10 |
camarolover2
how many cars do they get through in an hour. do you stay on the site or are there motels close by.
12-30-2014, 06:35 PM | #11 | |
Speed Freak
The vast majority of contestants stay in local hotels. You can pay a fee to park an RV on site but there are no hook-ups. You have to run generator power and watch water consumption. I always rent an RV, It is very convenient to have your kitchen and bed right at the track. You really can't get in line at 4 am if you are not parked on site. They won't let you through the gate at 4 am if you are not registered as an overnight guest. If you come in when they open the gate there will be 100 cars on the grid already that got in line at 4 am.... That means your first run of the day will be at 10am, and the temps and wind will no longer be ideal. If you don't stay onsite it would sure help to have someone there that would put your car in line. I'm not going to register for the March event. The last 2 events I had not driven my car on the recent modifications at all until I drove it on the trailer to go to the mile. Both events, the car had not actually seen any real speed until I pulled it to the starting line. It is hard to trouble shoot a car where you get to make a pass once every 4 hours. A three second dyno pull in 4th gear does not equal a run to the limiter in 5 gears against wind resistance. My car is not running now and registration is less than 15 days away. I'm not going to register again until I have a running car. I have gone 200, I'm not going back until I'm certain I can run full power for the full mile. Never happened for me the last 2 times.... But then again the very first time I registered, my car was running fine and then I blew the engine at eagles canyon and missed the entire event because I couldn't get a new engine in the car before the mile....I haven't had real great luck at the mile.....
12-30-2014, 06:44 PM | #12 |
camarolover2
what happened at eagle canyon
12-30-2014, 08:26 PM | #13 | |
Drives: Jaguar F Type Join Date: Dec 2014
To the op no you don't need a roll cage until 200mph. |
12-31-2014, 12:39 PM | #14 |
camarolover2
Thanks
