08-12-2022, 02:13 PM | #1 |
Drives: Chevrolet Camaro ZL1 1LE Join Date: Oct 2021
Warning for you guys running headers…
Protect this harness. We pulled mine to inspect it and we caught it just in time. We’re applying some heat shield. Passenger side under the strut tower.
I noticed that in hard RH corners the dash would go out and sensors would act up. This is definitely the culprit. Carry the hell on! |
08-12-2022, 02:16 PM | #2 |
Heads up
08-12-2022, 02:21 PM | #3 |
Drives: 2022 ZL1 1LE Join Date: Jul 2022
Yikes! Looks like a little bit of time protecting those wires and finding a way to strap them away from the heat is in order.
08-12-2022, 02:33 PM | #4 |
Drives: 2019 Camaro 2SS Join Date: Aug 2020
Route them behind the coolant tank. There’s room, it’s the easiest fix IMO.
2019 Shock 2SS A10. 2650@10psi/LPE HPFP/XDI+30/LT4 LPFP+JMS/Soler 95mm/Rotofab, E65, CSP 2” Headers/GESI GenII Cats. MM Wild/GM SG3 suspension/1LE Brakes, Velgen VF5 Wheels/GY SC3. JRE Tuned.
08-12-2022, 03:55 PM | #5 |
Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
Which headers are you using? I don't have any issues with my 2" Kooks.
08-12-2022, 04:13 PM | #6 | |
NG329 one of us should’ve mentioned this when you posted about your header install. There are many threads talking about relocating that harness as Chrome383Z mentioned. Hopefully it’s all good for you after you fix it.
08-12-2022, 05:52 PM | #7 | |
In all fairness, I'm probably taking turns a lot harder than you are. I noticed my dash going out in hard right hand corners. Upon inspection, we noticed that the harness had enough play in it to make contact with the headers under heavy lateral gravitational loads. |
08-12-2022, 06:10 PM | #8 | |
I'm just glad that we got to the bottom of it. Tipped my mechanic $100. He saved me so much more $$$ down the road. |
08-12-2022, 07:01 PM | #9 | |
08-12-2022, 07:32 PM | #10 | |
Here’s the install thread. https://www.camaro6.com/forums/showthread.php?t=607733
08-12-2022, 08:23 PM | #11 |
Drives: 2019 Chevy Camaro ZL1 M6 Join Date: Jul 2019
Ceramic coating on headers?
Kong Stage X Port, NW103, LPE HPFP, XDI +30 Injectors, ARH Headers, Flex Fuel, JMS Booster, AWE Touring, Elite E2-X CC. Stock heads, stock cam, stock pulleys: Tuned by KingLT1. 740whp Uncorrected on e50
08-12-2022, 09:04 PM | #12 | |
Extreme Online Headers https://www.camaro6.com/forums/showthread.php?t=607733 |
08-12-2022, 09:06 PM | #13 | |
You must be an older fellow because you're quite opinionated. |
08-12-2022, 09:07 PM | #14 |
