08-10-2022, 10:02 PM | #1 |
Drives: 2020 Camaro 2SS A10 Join Date: Jun 2018
Well went to the strip today again...
No real improvement but I think this place does the ef'd up 1/4 mile. Where its only 1/8th and they calculate the 1/4 based on that.
In any case here's the video along with slips. DA: ~2300-2400 Temp: 77-82 degrees F Tire Pressure: 26lbs Humidity: ~71% I think I was treating the tires as if it was the first time. Expected them to break loose but I never did feel them break loose or hear them break loose.
2020 Camaro 2SS A10 | Rebuilt by: CBI Street Cars | 2" SE LT Headers | 3" SE X-Pipe | 3" MBRP Axle-Back | Pri & Sec Cat Deletes | K&N Typhoon CAI | LT2 Ported | 95mm ZR1 TB | DOD Delete | BTR Stage I Cam | ECM, TCM & E85 |Tuned by: Shane Hinds | Dyno: 510 rwhp 472 rwtq
08-11-2022, 06:02 AM | #2 | |
As far as an estimate from 1/8 to 1/4, those calculators are NOT accurate for a street car. I tried a couple of those calculators with your 8.133 ET at the 1/8 mile, and they said 12.75 and 12.93 sec respectively for the 1/4. Not even close to your actual ET of 12.289 sec. |
08-11-2022, 07:37 AM | #3 | |
Even the guy in the truck next to me was surprised. We talked about it he said it looks like all my power is in the last 1/8th mile. Just have a gut feeling my mph shouldn't be that high given this time the DA was almost 1000 higher than the first time I went. The lower the DA the better the engine performs right? Then why does it seem like my car performs better in higher DA and more humid conditions? To me it sounds counter-intuitive am I wrong here?
08-11-2022, 07:44 AM | #4 |
Drives: like an old lady Join Date: Jun 2012
picking up 28 mph is suspect with those mods but not unheard of if you pfoot the first couple hundred feet.
08-11-2022, 08:19 AM | #5 |
considering that i just watched a video of a stock 1969 dodge daytona with a 426 hemi that did 0-60 in 6.1,and quarter in 14.1 i think that the newer musclecars are pretty respectable.oh yeah,it was getting 8 mpg too.
08-11-2022, 08:34 AM | #6 | |
But I never heard or felt the tires break loose on the launch.
08-11-2022, 03:53 PM | #7 | ||
My car ran within 1mph year between 3 passes. However, my 60’ dropping helped the most before the 1/8th. I feel you have an 11.70-11.80 in your setup. Keep practicing and don’t get discouraged.
08-11-2022, 06:20 PM | #8 |
Drives: LT1 Join Date: Mar 2022
Were your tire pressures the same?
08-11-2022, 06:38 PM | #9 |
26 psi on the rear 35 psi on the front
08-11-2022, 06:41 PM | #10 | |
Honestly not sure if 11.7 is doable, I aim shooting for a more reasonable 11.9 if I can. I'm a bigger guy so I expect the added weight is slowing me down some. Most of the other guys I see racing are probably 50-100lbs less than me. Even with mild expensive weight reduction I don't think I can cut a full 100lbs. After this day, My suspension feels loose, hearing loud clunky noises when going over mild bumps. Think I should have the suspension looked at before I go again.
08-12-2022, 08:00 AM | #11 |
08-12-2022, 08:16 AM | #12 |
i managed to go 11.80 on the street with that same tire and wheel setup.
you gotta pump those numbers up. those are rookie numbers.
08-12-2022, 09:36 AM | #13 | |
Next time I go, I'll try to get into it more from the start, and honestly my reactions although don't count are pretty bad, but figure I'll worry about that after I get better numbers. Like I said, I didn't feel the tires slip this time at 26 psi so figure that means I can get on it more at the start
08-12-2022, 09:42 AM | #14 | |
If the weather holds up next Wednesday I may go to the strip again see if I can work on my launches.
