07-26-2022, 02:57 PM | #15 |
Drives: 2019 ZL1 Join Date: Jul 2022
07-26-2022, 04:36 PM | #16 |
i have a ton of buddys with mustangs and they are pretty popular out here in cali
https://project6gr.com/
07-31-2022, 04:56 PM | #17 |
A few updates:
1) I took a wheel off and weighed it compared to my stock wheels (with tires) and it came in at 56lbs vs stock at 59lbs. So the new setup is lighter. 2) I noticed the contact area of the new wheel to the hub is about 1/3 of the size of the stock wheels which have a large mating surface. Does this cause additional stress or potential reduced performance under hard cornering? 3) My lugs don’t appear to have a great seat to the wheel either. The paint is scraped unevenly. Probably not an issue but something worth noting. Pictures below |
07-31-2022, 05:13 PM | #18 | ||
Drives: Chevrolet SS 1LE Join Date: Oct 2019
Therefore, the PSI will be higher but the total static friction (the force that keeps the wheel from moving on the hub) is the same. Quote:
Matt Miller
2020 SS 1LE |
08-01-2022, 11:30 PM | #19 | |
Drives: 2018 Hyper Blue 2SS 1LE Join Date: Aug 2018
OP- I never noticed what you are describing when I installed my wheels. I think your tire pressures are too high, I ran 32F and 30R cold on the street with my SC3s. Make sure when you mount them up that the mating surface is clean of debris and that the wheel sits flush on the mating surface and that the lug nuts are only contacting the their bevel in the holes.
2018 Hyper Blue Metallic 2SS 1LE with Nav, PDR, and track alignment
1:34.20 Willow Springs Big Track |
08-02-2022, 11:38 AM | #20 | |
Appreciate the feedback. I'll drop air pressures a bit, and may dismount and remount very carefully. Slowly hand tighten each lug while rotating the wheel back and forth to be sure the lugs are seating into the bevels. |
08-02-2022, 03:16 PM | #21 |
Out of curiosity, how do the seats in the wheels look? Are they showing witness marks of even contact?
08-02-2022, 08:10 PM | #22 |
Drives: 2021 LT1 10 speed auto Join Date: May 2013
Better make sure they are 120.0 MM bolt pattern and not 120.46 They may be stamped on the inside of the wheel or the box.... wrong picture sorry
