Old 04-11-2022, 12:32 PM   #1
2018ZL1
2018ZL1's Avatar
Drives: 2018 ZL1 A10 NFG
First TNT of the season
Finally got out to test out the new X-port and Methanol Injection!
Was going to Cecil which has good track prep but they cancelled at the last minute so I tried my luck at another track local to me... Made 3 passes and had troubles with the 2nd gear launch hitting the limiter on the 3-4 shift! This has never happened before! Thinking maybe it was spinning down track but I am not sure. This slip is from a run where i started in 1st gear, had to pedal it out of the hole, hence the 1.755 short time but after that this thing pulled like a freight train! Didn't set a new PB on ET but the MPH is my best! Its been 1.4X in the 60 foot pretty consistently so i figure if I can get that it should run sub 9.50's!
2018 ZL1-NFG-A10
New Iron L8T
9.32 147MPH
2018ZL1 is offline   Reply With Quote
Old 04-11-2022, 02:19 PM   #2
4thCamaro
4thCamaro's Avatar
Drives: Chevy Camaro 18’ SS 1LE
Good Run
FBO 18’ SS 1LE
4thCamaro is offline   Reply With Quote
Old 04-11-2022, 06:48 PM   #3
2018ZL1
2018ZL1's Avatar
Thanks... was hoping for a mid 9's run but the track wasnt gonna be having any of that!
2018 ZL1-NFG-A10
New Iron L8T
9.32 147MPH
