01-06-2020, 05:12 PM | #1 |
Drives: 2016 Camaro 2SS Join Date: Feb 2018
2016 Camaro SS power steering noise
While having engine out for my build and to keep from having to take car to local dealer for the power steering bolt recall I removed the bolts and powers assist motor from the steering rack and put a light coating of anti seize on mating surfaces and bolts then installed motor back to rack. Steering works fine but I get a grinding noise from the front steering rack when I turn full lock on both directions only when parked or lightly rolling turning out of parking spots. Did I mess something up by removing motor from steering rack or does the touque sensor or steering angle sensor need calibrated so the motor doesn’t try turning past full lock?
Tags |
electrical, issues, power steering, sas, steering angle sensor |
