Old 07-12-2023, 05:33 PM   #1
Jacobs__Garage
Drives: 2017 Chevy Camaro SS
Launch Control Issue
Recently got a drag pack, I have noticed my launch control isn't properly working. Car has an Lt4 blower, is an A8 with trans and ecu tune. Have tried different things but the launch control still isn't working properly.
With launch control engaged, the rear tires immediately begin spinning for about half a second and the car lurches forward a few inches, stops spinning, starts spinning again, stops, and so on. Once I let off the brakes, the car seems to properly launch.
I am wondering if anyone might know what is causing this to happen. Could this be a tune issue? Torque Converter?
Jacobs__Garage is offline   Reply With Quote
Old 07-13-2023, 11:42 AM   #2
6spdhyperblue
Drives: 6th gen
To get the car to launch harder with a tune, typically you’ll have to give up launch control
‘16 1SS M6 LT2 intake + boltons on DR 11.0@126+ (Sold)
Old 07-13-2023, 12:29 PM   #3
cjperformance
cjperformance's Avatar
Did you change either the front or rear dia diameter compared to stock? If all you changed between working/not-working was tires, I suspect tire dia may be a factor.
Sounds weird, but tire dia change can play all sorts of hell on ABS and TC.
DSX Aux Low Side | LT4 high side | Flex Fuel
TooHighPsi Port Injection (installed & tuning)
CircleD 3K Stall | QA1 CF Driveshaft
Forgestar F14 Drag 17x10 NT555R2 305/45/17 Rear
Forgestar F14 18x8 NT555G2 235/50/18 Front
10.84@131 w/4.13" pulley
??.??@??? w/3.7" pulley (installed & tuning)
Old 07-13-2023, 01:00 PM   #4
JSH
JSH's Avatar
Drives: '20 ZLE
I've been a member here for three years, and the consensus is that launch control isn't worth wasting time on. It has too many issues.
'20 ZL1 1LE A10,
OEM short block, LME heads/valve train, E2650.
100+ octanes, no eth, no meth, no N2O.
2/23 - 1031/1004 wheel.
4/23 - 1.41/9.61/145 at DA 7000 ft. (only made five passes).
2/24 - LME 390, E2650, FBO, 100 oct.; 1116hp/ 1063tq; 109 oct. dyno next.
Old 07-13-2023, 06:07 PM   #5
Jacobs__Garage
I would probably agree and just won't bother with it anymore. I just need to lower my psi when doing digs on unprepped surfaces. Have had trouble hooking through first and second on the ET Street Rs which is why I thought launch control might be a better option.
Old 07-13-2023, 06:55 PM   #6
joekd
Drives: 2018 Camaro SS vert
A decent driver and do the job better then the OEM launch control
I had my car at a drag day, was a lot of card breaking down so I was just doing hot lap runs. Would do one with LC, comp mode, let car shift (a*), next with same but without LC, then do same in sport mode, etc
By about run #4 or 5 I was getting better times then LC could do
joekd is offline   Reply With Quote
Old 07-14-2023, 09:16 AM   #7
laynlo15
laynlo15's Avatar
Drives: 2022 Lt1 A10
If your trying to use that at the track it just won't launch as fast as just flat footing it. I've tried everything between 3 cars and you'll always run slower. I tried launch control on the street and wasn't impressed with either of the cars.
Old 07-15-2023, 07:59 PM   #8
lt4camaro
lt4camaro's Avatar
Drives: 2021 LT1 10 speed auto
Its been known and proven over and over, a super good driver will always do better 0-60 or 1/4 mile passes with the nannies off.
lt4camaro is offline   Reply With Quote
Old 07-27-2023, 01:59 PM   #9
BigDawgMuscleX
BigDawgMuscleX's Avatar
Drives: 2019 Camaro ZL1 A10
Despite what the data has shown for LC vs idle launches, my car has consistently ran respectable times in the 1/4 with a 1.5x 60ft on the street with just a puddle burnout or two and using launch control. The trick for me is I've always used sport mode/competitive mode. It doesn't give you the LC settings like track mode but has never bogged the car or messed it up like track mode has.
Now.. been going through revision tunes on the same set of mods but have also added the front skinnies 28x6 tire.. and doing my first test passes with it it's now doing the same exact thing you've mentioned.. sits for a split second with the rpms and just jerks forward and tries to reset but keeps jerking and isn't working. Someone mentioned the ABS could be getting out of whack readings or whatever for the increased tire height.. I believe stock is 26.8" and the skinnies are 28".. rears have always been 28" (325/50-15) but all of a sudden its doing that jerking..
The reason I've used launch control is because in that sport mode setting it has hooked the car with ease and does NOT feel like it's pulling any power. Tour mode and all nannies off CANNOT hook the car up. I obviously want to run my fastest times but with all the testing I've done, the launch control has been the safe bet for me.
Best thing for me and you to do is probably put the stock fronts back on and test it again OR of course learn to launch it off idle.
2019 A10 ZL1
Just a bolt on LT4
BigDawgMuscleX is offline   Reply With Quote
Old 07-27-2023, 03:22 PM   #10
lt4camaro
lt4camaro's Avatar
Originally Posted by BigDawgMuscleX View Post
Despite what the data has shown for LC vs idle launches, my car has consistently ran 9s in the 1/4 with a 1.5x 60ft on the street with just a puddle burnout or two and using launch control. The trick for me is I've always used sport mode/competitive mode. It doesn't give you the LC settings like track mode but has never bogged the car or messed it up like track mode has.
Stock should be 27.7
Old 07-27-2023, 03:30 PM   #11
6spdhyperblue
Drives: 6th gen
ZL1 is 26.8 for the front and 27.2 in the rear
Old 07-27-2023, 04:35 PM   #12
lt4camaro
lt4camaro's Avatar
Didnt know that, most configurations are 27.7 front and rear.
