Old 05-19-2020, 12:21 AM   #1
yose
Drives: 2017 camaro 1le
Help! clunking
Car is vibrating under the drivers seat, start up is lower toned, and there is a clunking noise in 2nd and 3rd a lot. There are 5 videos if you could watch and help me out!
yose is offline   Reply With Quote
Old 05-19-2020, 09:19 PM   #2
yose
No one?
Old 05-26-2020, 01:52 PM   #3
Azmedian
Azmedian's Avatar
Drives: 2020 Chevrolet Camaro 2SS/1LE
Exhaust hangers loose?
Check your exhaust attachments, might be a pipe loose or just too close to body
Azmedian is offline   Reply With Quote
Old 05-26-2020, 04:12 PM   #4
SSDan
SSDan's Avatar
Drives: 2016 1SS 6MT NPP
Can't tell just from the video.
Suggestions:
- Check the bolts where the half shafts bolt up to the rear diff. Several people have found those backed out and loose. Some have even had the bolts back all the way out and the half shaft fall off!
- As mentioned the other thing to check would be all the exhaust connections, brackets and hangers.
- Often vibration under your seat is an indicator of something out of whack with the rear suspension/wheels being loose or out of balance
Good luck - tracking down noises like that can be frustrating!
476 rwhp/440 rwtq (sold)
Old 07-09-2020, 12:28 AM   #5
Azmedian
Azmedian's Avatar
Did you ever find out what it was
Any resolution
:Moon:
2020 Camaro 2SS 1LE
1968 Camaro
Az
