05-07-2020, 12:57 PM | #15 |
Drives: Black Join Date: Jan 2017
Wow that is really low. As most of you may know, the trucks have the same drivetrains. We actually have a trans thermostat that doesn’t start flowing until 190 degrees. So even in the dead of winter I’m at 190-200 degrees.
I’d say you guys have absolutely nothing to worry about with trans temps. |
05-07-2020, 08:17 PM | #16 |
Wish the C7 corvette had this problem they heat up pretty quick.
Orange Krush II
05-08-2020, 08:29 AM | #17 |
Drives: 2017 SS 1LE Join Date: Feb 2013
Transmission temps are nothing to worry about in this car. I'm in FL, and in the summer time, daily driving the fluid would get to 100-110. On track (Sebring and The FIRM), I'd see 190-205 or so. I can pull the PDR data if need be.
This car is no issues with heat, period. I've done many sessions at Sebring and the only thing that made me come off track is session time runs out, tires give up, low on gas.
2017 SS 1LE (sold)
Nightfall Gray |
05-17-2020, 02:07 PM | #18 | |
Drives: Chevy Camaro Join Date: Nov 2019
05-18-2020, 11:39 AM | #19 |
Drives: '18 1SS 1LE Join Date: Sep 2017
Normal driving on the street after a couple hours, ambient in the low 60º's, I was around 110-115º. Ambients in the low 80º's and I was closer to 125-135º.
Cooler days in the 40º's and several hours still nets a gauge stuck at 100º. I think the highest I've seen on the street in the summer is about 150.
'18 1SS 1LE Black, PDR
08-03-2020, 12:37 AM | #20 |
Drives: 2018 2SS 1LE Join Date: Feb 2018
checking back in here because this situation still confuses me...
Was driving 70 mph highway and some stop and go for a couple hours this past weekend and the fluid was slightly over 150 in 80-100 degree ambient temperatures. That's at 1600-2000 rpm cruising the freeway. Have Redline D4 ATF -- can't recall ever seeing this on my 2016 with Amsoil but maybe I never checked when it was hot. I recall seeing people say 150 at the track so wondering if this is cause for concern? Also wondering if maybe it was because I screwed something up on the rear diff fluid swap? have since filled up the trans fluid all the way to see if that makes a difference
2018 1LE
2nd 6th gen SPL Toe Arms/Brembo HTC64t/Corsa NPP/Tremec MTF Fluid |
08-03-2020, 01:32 AM | #21 |
Drives: 2016 Camaro 1LT Join Date: Jan 2016
My old fluid having v6 has the trans fluid moving between 160 and 190 in fairly regularly traffic.
It has about 35k miles on it. I'll be switching the fluid to the new formula this week over the course of the next couple weeks. But I get the feeling that it is normal to see high trans temps in traffic vs cruising or even some tracks |
08-03-2020, 07:37 AM | #22 | |
Drives: 2018 Camaro V6/RS Join Date: Nov 2018
08-04-2020, 09:00 AM | #23 | |
I honestly wouldn't be that concerned with temperatures. Of course keep an eye on them when on track to make sure everything is working as designed. But as long as there is no damage to any of the heat exchanges/radiators up front and all fluids are topped off, this car is ready to be beat down on the track. Again, I can show some of my PDR data if need be, but my car literally NEVER missed a beat. At Sebring in August a couple years ago:
2017 SS 1LE (sold)
Nightfall Gray |
08-07-2020, 12:39 AM | #24 |
Drives: 2017 Camaro 1SS Join Date: Jul 2016
Makes me think I have something wrong with mine. Last time I drove it, temps were in the 80’s and trans temp quickly got up to ~150* of just normally city driving.
2017 1SS Hyper Blue M6
08-07-2020, 11:38 AM | #25 |
Yea, regardless of the car, I start with coolant and trans fluid temps being about the same when warmed up
08-08-2020, 09:44 PM | #26 |
So I’ve got two questions, hopefully y’all can help... maybe I’m reading this wrong but per GM...
“6. Install the transmission fill plug to the transmission and tighten the fill plug to 27 Y (20 lb ft). Note: Inspect the clip for proper retention on the cooler line to the bracket. Replace the clip as necessary. 7. Reconnect the clip (1) retaining the cooler pipe to the transmission bracket. Note: Ensure the clutch pedal is NOT depressed. 8. Run the engine in Neutral for two minutes to allow the fluid to recirculate. 9. Remove the fill plug and verify the fluid level is 3.2 mm (1/8 inch) below the fill plug hole. Add or remove transmission fluid as necessary. 10. Install the transmission fill plug to the transmission and tighten the fill plug to 27 Y (20 lb ft). 11. Lower the vehicle.” How can the clutch pedal not be depressed when you need to start the car to run in neutral for two minutes?! And second... after a short drive, this was my trans temp.... The rear cooler lines were hot, like the pump was working, but the front cooler seemed cold. Not even close in temp to the cooler lines going to the rear. But I pulled the lines off on each side and there’s fluid on each side of the cooler. So why is my trans getting so hot? I know it’s a manual and I probably shouldn’t be worrying about this issue, but it seems hot especially when I read other posts and everyone says that theirs hardly ever moves off the 100* line. Using the GM fluid, and outside temps were in the 90’s while I was driving. Thanks for any help guys!
