03-07-2020, 10:53 PM | #1 |
Drives: 2011 Camaro 2Ss M6 Join Date: Dec 2011
MASSIVE Part out
Hello,
While this is unfortunate I am considering parting out my build. Emphasis on considering... I am going to post up the parts that will be for sale and if they will require your stock units to replace in addition to cash. I will be updating with pricing as i have time. This is only to gauge interest for now. All of these parts have little to no use so understand they will be priced accordingly. Discounts will be applied if parts purchased in groups (I.E. Engine and Blower, Differential W/ Drive shaft and half shafts ETC) Max Effort Forged LSR Long block ready for all of the boost! This will require a stock SS/M6 long block in addition to cash. Engine Build -•LSR Short block LSR-SD2X -•AFR Mongoose Heads Upgraded Exhaust Valve to Inconell -•Callie’s Dragon Slayer Crank -•Callie’s Ultra I beam Rods -•Weisco pistons -•Weisco Piston wrist pin upgrade -•BTR Stage 4 PD Cam -•Johnson Lifters 2116LSR -•Moroso Copo Oil pan -•ARP Main Studs -•ARP 6 bolt Head Studs -•Cometic Head Gasket -•C5-R timing chain -•Clevite Main Bearing -•Clevite Rod Bearings -•ACDELCO Header Gaskets -•NGKTR8IX spark plugs •Magnuson Heartbeat 2300 (The blower will be packaged with the following items) -103mm Snout -103mm Nick Williams Throttle body -Roto-Fab 5'' Air Intake •Prospeed ZL1 Catch Can •ZL1 OEM Hood (Black With Carbon Fiber Insert) •AFCO race radiator •Prospeed ZL1 Heat exchanger upgraded to 1” Lines •Stewart EMP Heat exchanger pump •Rotofab Reservoir Fueling (This will sell as a complete kit) -•Fore L4 Tripple system -Primary pump is a 450 -Secondary pumps are 525's -LSA/LS9 Fore Fuel rails -10 feed and return lines -Flex Fuel sensor •Injector Dynamics 1700's •American Racing 2” long tubes (Coated by Jethot) •Corsa ZL1 Catback Exhaust (Black Chrome Tip's) (Sold with resonators) -Solo Performance resonators •Drive Shaft Shop One Piece Driveshaft •ZL1 Rear differential (This will only sell to someone with a stock 3.45 M6 Differential to swap with me in addition to cash) •Drive Shaft Shop 1400+ Half shafts (These will only be sold to someone with stock SS M6 half shafts to swap with me in addition to cash) •KW Variant 1 Coilovers (Will only sell to someone with stock SS pieces to swap with me in addition to cash) •Powdercoated OEM ZL1 Wheels (Wrapped in ToyoR888r's) (Will require stock wheels in addition to cash) •Beadlock Weld S71 15'' Ceramic Coated Wheels (Wrapped in MT ET Street pro 275/60/15) |
03-07-2020, 11:48 PM | #2 |
'It's an experiment'
Drives: [COTW 2/09/15] '11 GPI LSA SC Z/LE Join Date: May 2014
Damn! That was a very nice build, what’s next?
-Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari See My Build: http://www.camaro5.com/forums/showthread.php?t=385577 |
03-24-2020, 04:41 PM | #3 |
Drives: Camaro 2011 RS Join Date: Jun 2015
hood up for grabs?
Sometimes Rattlecan rims look good...
06-10-2020, 08:30 PM | #4 |
Drives: 14 ss camaro summit white Join Date: Oct 2014
Price on headers?
2014 ss camaro
Stainless works long tubes , rotofab cai , vararam wedge , muffler delete,cat delete ,resonator delete , x pipe 2019 sierra duramax 2500 all terrain x 2001 trans am Lsx 408 ci rebuild in progress(dead project) 1967 camaro Sbc 327. |
06-11-2020, 03:39 PM | #5 |
06-11-2020, 03:40 PM | #6 |
06-12-2020, 12:18 AM | #7 |
Did the blower go with the car too?
2014 ss camaro
07-01-2020, 11:39 PM | #8 |
Drives: 2017 zl1 ,2010 SS /RS L99 Join Date: Sep 2017
Anything left ?
Hi there anything left from the parts u had listed for sale ?
2017 zl1 - rotofab CAI , PDR , Nav .
2010 camaro SS - Procharger D1 sc (Stage 2 with upgraded intercooler)+ whole lot of other goodies ( too many to list ) |
07-08-2020, 01:58 AM | #9 |
08-05-2020, 09:14 AM | #10 |
Drives: 2013 Camaro SS 6-Speed Join Date: Nov 2017
Still have the Corsa??
2013 Camaro 1SS 6-Speed LS3 All stock.. For now... |
09-30-2020, 01:43 AM | #11 |
Drives: camaro 2ss Join Date: May 2020
How much are you asking for the hood?
