dave@hennessey
Old 06-30-2017, 11:16 PM   #1
nross33
nross33's Avatar
Drives: 2015 Camaro LT- Gone 2010 Camaro SS
2010 SS Major Issues
Hello all, so I was driving on the freeway and my car started off with a service stabilitrak light. This has came on a few times over the last few weeks but then all hell broke loose. Idle is weird, gauges acting up moving up and down, AC won't blow cold, transmission keeps clicking and not showing a gear on the screen, every warning light imaginable, low power, reverse lights stuck on in drive etc. Where to begin here...
nross33 is offline   Reply With Quote
Old 06-30-2017, 11:32 PM   #2
Jazzzed
Jazzzed's Avatar
Yeah that seems to be a substantial collapse of all systems. The place to start would be the codes... both engine and trans codes.
Jazzzed is offline   Reply With Quote
Old 06-30-2017, 11:40 PM   #3
TigerFA
TigerFA's Avatar
Drives: Camaro 2SS 2017 Red Hot
Loose plug on the ECU? Check it out!
Gesendet von iPhone mit Tapatalk
Greetz Steve
2017 2SS, 2014 2SS 1LE, 2014 2SS
TigerFA is offline   Reply With Quote
Old 06-30-2017, 11:51 PM   #4
Welker2
Ret AF, cancer survivor
Welker2's Avatar
Drives: 2013 Camaro 2SS/RS & 2006 Corvette
I would also get your battery tested at your local auto parts store. I know Corvettes are infamous for everything going 'wacky' like you've described when the battery starts to or goes bad. The battery will have enough charge to start, but every (warning) light will go off, other electrical issues will occur and the car will run like you know what.
Welker2 is offline   Reply With Quote
Old 07-01-2017, 01:23 AM   #5
CamaroFred
CamaroFred's Avatar
Drives: Miss Con Ception
Yes, battery.
I bought a new Delco last year for my 2011.
Oops I see you have a 2015. Should be under warranty.
2011 1SS/RS LS3 CGM
CamaroFred is offline   Reply With Quote
Old 07-01-2017, 02:39 AM   #6
ride4mud
ride4mud's Avatar
Drives: 2011 2SS Vert
Battery
Battery or Battery Cables. Had this happen on both my Cruze (bad ground cable) and on my Sierra (bad positive cable). Usually the crimps go bad.
2011 2SS
ride4mud is offline   Reply With Quote
Old 07-01-2017, 02:47 AM   #7
IMadeYouReadThis
IMadeYouReadThis's Avatar
Drives: 02 Camaro SS 6M / 11 GMC Sierra
Crapped out computer is my guess. Any lighting storms around the time you started having problems? Parked under power lines lately?
IMadeYouReadThis is offline   Reply With Quote
Old 07-01-2017, 11:24 AM   #8
blue-bayou
blue-bayou's Avatar
Drives: 2010 IBM SS/RS/Stick
Most likely an electrical issue- ground, cables, loose connection,etc or maybe the BCM is going out(hopefully not)
blue-bayou is offline   Reply With Quote
Old 07-01-2017, 11:50 AM   #9
Wizard1183
Wizard1183's Avatar
Drives: ABM SS2/RS M6
Send a message via Yahoo to Wizard1183
Check your spark plug wires as well! My 2014 GMC Sierra had a plug come off and stable track lit and truck started acting crazy. They thought it was the head. Fixed it. I was driving same thing happened again. I pulled off aside and. He led it. Found spark plug wire was disconnected. Plugged it back. Good ever since
Life is short, drive it like you stole it!
Wizard1183 is offline   Reply With Quote
Old 07-01-2017, 12:10 PM   #10
IOMCamaroSS
#PrimeCamaros
IOMCamaroSS's Avatar
Drives: IOM '10 Camaro SS
Very well could be the battery. I began getting the stabilitrak light on startups this last spring on my 2010 then checked the forums and saw it was common indicator the battery was going bad. I replaced it before it got any worse. Being that you have a '10, it may still have the original battery... they last a while. Maybe have that tested first?
instagram: @IOMsupersport // @PrimeCamaros
IOMCamaroSS is offline   Reply With Quote
Old 07-01-2017, 03:06 PM   #11
nross33
nross33's Avatar
Hey guys, the wiring harness is melted from the headers, but it's been like that for years, could have finally crapped out I guess. My guess was ground or battery/alternator. I live on the beach In Southern California so lightning storms are non existent. It's at my dealer being diagnosed and my service writer is my friend and neighbor so whatever it is it will get done
Old 07-01-2017, 06:14 PM   #12
Cyber10
Cyber10's Avatar
Drives: 2010 Camaro 2SS/RS
My first thought was electrical as well, pretty much the only way you're going to have that many issues across the board unless you're really unlucky and break a bunch of stuff at once(and by unlucky I mean don't go outside the next time there's lightning).
Test the battery and then go from there.
491 hp/438 tq
LS3 Conversion | Comp Cam Custom Grind | Mast Heads | Comp Cam Push Rods | LS7 Timing Chain | 180 Thermostat | Ported Intake | Ported TB | SLP UDP | K & N CAI | Custom 3800 Stall Converter | Aluminum 1 Piece Driveshaft | Kooks 1 7/8" LTH | High Flow Cats | ARH 3" Exhaust | ARH Mufflers | Eibach Lowering Springs | BMR Floor Brace Subframe Connectors with Tunnel Brace | BMR Moly Lower Rear Control Arms | Oracle LED Halo Kit
Cyber10 is offline   Reply With Quote
Old 07-01-2017, 09:27 PM   #13
Avenging Orange
Avenging Orange's Avatar
Drives: 2010 Inferno Orange 2SS/RS
Yep...under warranty. Dealership is where it should be.
2010 Inferno Orange 2SS/RS M6 Black Leather, Sun Roof, OBX Headers, Borla touring axle back, Cold Air Inductions CAI , non synthetic fluids, BMR total bushing upgrade/1" lowering springs, DSE 32mm rear sway bar. GM fe4 shocks/struts/LCA's, AAM 3.91 diff, Vertini RFS1.8 20x9 +30. Conti ExtremeContact Sport 275/35/20. sjm autoprod ABL dash kit. Mike Norris tuned 413/419.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!!
https://youtu.be/9JD9it6SmB8
https://youtu.be/xmelTlEzI34
KICKING CANCERS ASS SINCE 2015!!
Avenging Orange is offline   Reply With Quote
Old 07-02-2017, 07:18 PM   #14
Wizard1183
Wizard1183's Avatar
I'm still using factory battery. Although only 31k miles. Starts like a champ never has to boost it or charge it.
