03-27-2020, 09:02 AM | #1 |
Drives: Chevy Camaro Join Date: Dec 2019
Cutting Exhaust Pipe
I was going to swap out my muffler and was wondering if it's possible to cut the exhaust pipe using a sawzall while the car is on the ground
Would have to borrow a sawzall but didn't want to bug my buddies unless it seemed like it was possible. It looks like there may be enough room to get under there to do it but was curious if anyone has actually done it and if there were any tips to do it safely/right Thanks and hope everyone is staying healthy |
03-27-2020, 09:19 AM | #2 |
Drives: 2019 Chevrolet SS Join Date: Mar 2019
Get a tailpipe exhaust cutter from amazon its only like 10-20 bucks. Makes it very very easy to cut the exhaust pipes.
03-27-2020, 10:55 AM | #3 |
Drives: 2020 1SS 1le Join Date: Apr 2019
Yes the saw will work. The stock exhaust pipe metal is pretty soft
03-27-2020, 11:07 AM | #4 |
Drives: 2019 ZL1 / LE , 2014 CTS V Join Date: Nov 2015
[QUOTE=gchu;10754256]I was going to swap out my muffler and was wondering if it's possible to cut the exhaust pipe using a sawzall while the car is on the ground
Would have to borrow a sawzall but didn't want to bug my buddies unless it seemed like it was possible. It looks like there may be enough room to get under there to do it but was curious if anyone has actually done it and if there were any tips to do it safely/right Thanks and hope everyone is staying healthy[/QUOTE The tail pipe exhaust cutter will give you a nicer cut. However, if that doesnt bother you, fire up the Sawzall. |
03-27-2020, 04:41 PM | #5 |
You'll be there for a bit with a handsaw but if you have the time/patience you'll get it done
03-27-2020, 05:25 PM | #6 |
Drives: 2019 ZL1 Join Date: Jul 2019
It will work, but I would recommend an exhaust cutter like everyone is saying. When I installed my axleback, I kept it on the ground and used the sawzall and the cuts ended up being very angled/slanted due to the very limited room and had to be straightened out with an angle grinder.
2019 Camaro ZL1
03-28-2020, 06:37 PM | #7 |
Thanks for everyone's responses
Guess I'll have to debate on buying one for $30 (price of the pipe cutter with decent reviews) or just paying an exhaust shop to cut and do the swap for me. Seems like most people had gotten it down for around $100 for the labor.... |
03-28-2020, 06:50 PM | #8 |
Drives: '16 Garnet Red 1SS Join Date: Mar 2014
I paid $150 for installing the catback with NPP. Fair price imo.
'16 Camaro 1SS
'18 Miata GT Gone: '01 Camaro, '14 Camaro, '90 Miata |
03-28-2020, 07:54 PM | #9 |
Drives: 2019 Camaro 1LE Shock Candy Join Date: Mar 2016
Just make sure you have the extended blade to cut all the way thru, some blades are to short and just makes it more difficult.
LT4 1.7 Supercharger snout ported & 100% Meth
103 Katech TB, KATECH Custom Heads, DSX In-line fuel TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane. 2014 Mini Cooper countryman S All4 M6 daily driver |
03-28-2020, 08:52 PM | #10 |
Drives: Chevy Camaro Join Date: Jul 2019
A sawzall will go right thru, did it on my Borla on stock pipes
03-29-2020, 12:19 AM | #11 |
Drives: 2018 Camaro SS/1LE Join Date: Jan 2018
I stacked up some concrete pavers like a ramp to get the ass end up a lil higher.. I also got large hose clamps and put them on the exhaust pipe to help guide the sawzall blade and keep the cuts straight
03-29-2020, 08:12 AM | #12 |
Drives: 2016 SS Join Date: Oct 2019
Another vote for a tailpipe cutter. I rented one from O'Reilleys. While a sawzaw certainly works, I feel the cleaner, straighter cut of a tailpipe cutter is a better method.
03-29-2020, 09:38 AM | #13 |
Anyone use this tailpipe cutter from Amazon? Seems like it was hit or miss from the reviews cutting SS exhaust pipes
OEMTOOLS 27045 Tailpipe Cutter I do like DVS510's suggestion of using hose clamps to help keep the cut straight... I have a blade that is long enough to cut all the way through the pipe (had to cut off the X-Pipe of the NPP muffler I bought ). How high did you lift it with the pavers? It went through fine - except at the end the final cut it got stuck when the muffler shifted. Fortunately my son was out there to shift the weight so I could finish |
03-29-2020, 12:01 PM | #14 |
You can go to Walmart and get a plug in saw for 20-25$ and then buy some long metal blades. I only needed one blade. I backed the car up on pieces of wood to get it higher. The cut wasn't perfect but it works fine. I smoothed it out with sandpaper and threw the borlas on with a little.bit of copper gasket stuff. I been meaning to go back and cut another inch or two so the pipes fit in nicer.
