Old 12-04-2018, 09:11 AM   #15
BMWM.D.
BMWM.D.'s Avatar
Drives: ZL1/335i
https://www.camaro6.com/forums/attac...1&d=1540309056
This is the one that I did on my car. Worth a look in my opinion.
BMWM.D. is offline   Reply With Quote
Old 12-04-2018, 09:14 AM   #16
Jason18ZL1LE
Drives: 2018 ZL1 1LE
Originally Posted by BMWM.D. View Post
I would definitely check out the wiring near the passenger headlight. There is a service campaign to add extra protection to it, as it can rub on a sharp edge and cause all kinds of issues. The harness on my 18 had a heavy gouge in it, and I have no doubt it would have worn through given more time. I could definitely see this being an issue aggravated by turning.
There’s actually 3 different wiring related bulletins for these cars. I’ll try to find them.
We’ve inspected that harness and it doesn’t look worn through but perhaps I will undo some of the wrap and inspect further.
Jason18ZL1LE is offline   Reply With Quote
Old 12-04-2018, 09:19 AM   #17
BMWM.D.
BMWM.D.'s Avatar
Drives: ZL1/335i
I had a noticeable gouge in my insulation in that area, though I don’t have any issues with the car. If you don’t have any hard contact/gouging, then it’s probably fine. I have seen wires broken or damaged under insulation though. So I’d take a closer look.
Btw...I work next to a friend of yours. Small world.
Old 12-04-2018, 09:23 AM   #18
Jason18ZL1LE
Mine doesn’t have the added abbrasion sleeve but there is definitely a notch in the tape. The car is at GM right now for an unrelated issue so I will have them inspect it.
Old 12-04-2018, 09:37 AM   #19
BMWM.D.
BMWM.D.'s Avatar
Drives: ZL1/335i
Are they fixing the diff issue?
Old 12-04-2018, 09:58 AM   #20
Jason18ZL1LE
They are! Service manager said “you didn’t mod the differential so the way I see it, the warranty is in tact”
Old 12-04-2018, 03:46 PM   #21
Jason18ZL1LE
GM Called me and said they peeled back the insulation on the recalled harness and some of my wires were damaged under the sleeve. Hope this fixes me issue
Old 12-04-2018, 09:04 PM   #22
angryBits
angryBits's Avatar
Drives: ZL1 1LE A10
Which issue did you have on the Z06? The Stabilitrak or the fuel pump voltage?
Stabilitrak
Thats great news! Now we know in case this happens to anyone else.
Nothing sucks like hard to diagnose problems on a new car.
Current: 2019 ZL1 1LE A10
Mods: MPS4s Tires | Borla Atak | CF Steering Wheel
Previous: 2018 ZL1 1LE M6 | 2017 Z06 Z07 M7 | 2017 GS A8 | 2015 ZL1 M6 | 2013 GT500
angryBits is offline   Reply With Quote
Old 12-04-2018, 09:19 PM   #23
Jason18ZL1LE
With my luck I won’t believe it’s fixed until I see it. But it does explain the weirdness
Old 12-04-2018, 09:41 PM   #24
waterman
waterman's Avatar
Drives: Grandad's C2 L89
Can you link me to the TSB?
Here is that TSB that I believe you are looking for.
https://www.camaro6.com/forums/attac...1&d=1543981177
Here are 2 more that you might have addressed while they have your car.
2018 ZL1 1LE sw/PDR
Old 12-04-2018, 09:44 PM   #25
waterman
waterman's Avatar
I should have read BMWM.D.s post. looks like he already hooked you up.
2018 ZL1 1LE sw/PDR
Old 12-05-2018, 08:42 AM   #26
kwav8r
Flyin NOE
Drives: 2018 ZL1 (A10)
We need a damn 'sticky' or section dedicated to TSBs and Recalls....
Old 12-05-2018, 09:11 AM   #27
BMWM.D.
BMWM.D.'s Avatar
Drives: ZL1/335i
Awesome. I haven’t looked at a wiring diagram to figure out what exactly is in that harness, but I’m pretty confident this will fix your issue.
Old 12-05-2018, 09:36 AM   #28
kwav8r
Flyin NOE
That's great news! Let us know if it actually fixed the problem.
