08-08-2022, 07:59 PM | #1 |
Drives: 2018 Camaro 2SS Performance Join Date: Nov 2017
Shifting problems after tune..
I have a 2021 Camaro LT1 10spd auto bolt-ons tuned on E85. I added a ported 95mm tb and got it retuned. After the second tune I went out to test.
I usually hold it in 2nd gear in manual mode stomp the pedal and push the shifter back in into drive and it would redline and shift gears. This time when I did it once I pushed it back into drive it up shifted instead of staying in gear to near taching out. Not sure what the cause of this is and I have tested numerous times now and it still shifts as I push the shifter back into drive when I’m flooring it. I don’t think this is normal and had anyone experienced this after being tuned? |
