07-12-2022, 05:00 PM | #1 |
CatchMeIfYouCan
Drives: 17 1SS(prev), 19 2SS Manual Join Date: Mar 2019
Failing Emissions Test - 2019 Camaro 2SS M6
Has anybody experienced emission issues with your 6th gen Camaro?
I have a 2019 Camaro 2SS M6 that has failed multiple emissions test recently due to READINESS = FAIL2, more specifically the Catalyst and the Oxygen Sensor. This is my first required emissions for the car and my registration is due at the end of July (most likely will need an extension). At this point, I'm ready to throw the whole car away. How we got here: 1. Failed emissions (June 20th), was instructed to "put miles on the car" 2. On the same day I cleared out the tank after driving roughly 60 miles and the test failed again. I didnt really think anything of it and figured I would just try a different place at a later date. 3. A week later, I filled to a little over 2/4 tank, drove to Duluth back to College Park (100 miles total) Failed third test... 4. On the same day after the 3rd failed test, I had my mechanic run test to see if he could find the issue but the oxygen sensors were reading perfectly fine in the device he was using. At this point he recommended the dealership. 5. The Catalyst failure is weird because my check engine light should be on if it were really an issue, right? I only have roughly 35,000 miles on the car. Its not my daily driver anymore as I have been working fully remote since March 2020. Currently its at a local (Union City) Chevy dealership where they told me it could possibly take 2-3 weeks before somebody even takes a look at it, let alone fix it. Again, has anyone heard of or experienced this? On the picture, they listed the transmission as an automatic but thats an error..
2019 Camaro 2SS M6
#AtlantaDrivesChevy IG:1ybmceo |
07-12-2022, 05:13 PM | #2 |
Drives: 2023 ZLE M6 Join Date: Jun 2022
Is the car tuned?
2023 ZLE M6 Borla S-Type Catback | Rotofab CAI | Soler TB | MPI Lid |
07-12-2022, 05:25 PM | #3 |
CatchMeIfYouCan
2019 Camaro 2SS M6
07-12-2022, 08:02 PM | #4 |
Who Needs to KNOW?
Some drive cycles have to have warm up / cool down before they will complete. Others require driving specific number of miles above certain speed within certain throttle settings to trigger.
Can't reset codes either or readiness monitors reset. By same token, can't have dead battery either.
ing for grip.
07-13-2022, 09:19 AM | #5 |
Your report is saying you failed because "car not ready to communicate with on-board pollution controls."
Some info: https://dmv.vermont.gov/sites/dmv/fi...ack%20Card.pdf https://deq.nc.gov/about/divisions/a...information#G8 I doubt this is an actual ECM problem. Was battery recently disconnected? I would check the battery. If battery is going bad it might cause this. My reading says the combo of O2 sensor and catalyst sensor not ready points to weak battery. BTW, not sure what a catalyst sensor is. Is that the post-cat O2 sensor? |
07-15-2022, 03:59 PM | #6 |
Drives: Camaro 1SS A8 Vert Join Date: Sep 2018
Tune it for E85...
07-22-2022, 01:15 PM | #7 |
CatchMeIfYouCan
Update: I ended up putting it in the dealership, it took them about 6 days to complete the “work”. They said the system needed an update and needed to put at least 200 miles on it. They got me for $150 and at that point I just hoped the car would just pass the damn emissions test finally.
I got a tag extension and put about 300 miles on it over the course of 2 days. Went to go get another test fresh off the road and FAILED. Evaporative System and Oxygen Sensor but the Catalyst passed. I’m taking it back today before they close.
2019 Camaro 2SS M6
07-22-2022, 04:23 PM | #8 |
That readiness is a SOB for getting EVAP ready. That drive cycle is brutal according to GM procedure.
IIRC, there’s a temperature threshold, fuel level, etc. that will stop the readiness from completing. (This isn’t specific to EVAP) I just did a search and this is what I remember reading a few years ago. It’s rarely discussed by emissions station or technicians at various garages. https://www.rangetechnology.com/blog...tor_procedure/
