07-02-2022, 02:13 PM | #1 |
Drives: Camaro 2SS V8 Join Date: Jun 2022
Braking vibration
Hello,
For couple of weeks I have a quite bad vibration and shaking while braking, around 70-120km/h. I changed the brake rotors and pads, and was exactly the same, I thought that maybe the rotors are not good so I changed them with the seller. The second set was exactly the same. So I decided to go with OEM parts. Meanwhile I did changed the wheel hubs too. Now is the same with the OEM rotors and pads too. I did checked everything, I have no problems at wheel, at steering etc. Can this be from rear rotors too ? I must say that there’s no shaking or vibration in the steering wheel while braking, only in my brake pedal, and overall on the car. Did somebody had the same problem ? I really don’t know what to do, and it’s so annoying to drive it lol Thank you ! Hope you enjoy your day! |
07-11-2022, 07:53 PM | #2 |
same problem
i wish someone could come up with a solution, I'm having the exact same issue. change the front hub bearings, change the front rotors and brake pads still having a real bad vibration. my shifter be shaking like it's about to fall off. the only next thing to do is the rear.
07-12-2022, 01:21 PM | #3 |
Let me know after you change rear ones if it’s getting better. Mine are looking good, so I don’t take really want to change them for nothing.
07-12-2022, 05:40 PM | #4 | |
Drives: 2023 Chevrolet Camaro 2SS 1LE Join Date: Jan 2020
