07-31-2022, 08:44 PM | #15 | |
If you’re NA it can often times make sense to go with the shorter wheel/tire. But that wasn’t the case here.
07-31-2022, 09:23 PM | #16 |
Yep...PD automatic needs the height.
2016 NFG 1SS A8
07-31-2022, 10:30 PM | #17 | |
Drives: Chevrolet SS 1LE Join Date: Oct 2019
Matt Miller
2020 SS 1LE |
08-01-2022, 05:26 AM | #18 | |
In this case it was presented as an either/or, and as King mentioned there are cars getting into the 7’s on 275s if you can get the height and sidewall optimized, so the width plays a smaller factor than most believe.
08-30-2022, 09:28 AM | #19 |
Drives: 2021 LT1 10 speed auto Join Date: May 2013
A 275 40 20 is 28.7 inches tall, wouldnt that create a few possible issues?
09-12-2022, 07:33 PM | #20 |
Drives: 1SS Summit White 6 speed Join Date: Jul 2017
What's worst case scenario the tire rubs the felt and hits that wiring harness ?
16 1SS M6 White
Magnuson 2.3 Heartbeat Roto Fab Solo Performance Cat deletes and Axleback Hurst short shifter #'s coming soon Riaction coilovers 1LE sway bars BMR mm BMR chassis brace Flow one 19" wheels wrapped in Mickey Thompsons 02 Z28 M6 35th anniversary 80k miles T-tops Leather Bolt ons Joy to drive this classic every day! Daily Driver |
09-12-2022, 07:40 PM | #21 |
09-12-2022, 07:41 PM | #22 |
09-12-2022, 07:57 PM | #23 | |
On the rear wheel well there is a wiring harness. If tire is too wide it can rub through the felt splash guard and hit the harness This applies to SS and LT1 trim only I believe
16 1SS M6 White
09-12-2022, 08:03 PM | #24 | |
inch wide tire will take care of most peoples needs and create no issues whatsoever. |
09-12-2022, 08:08 PM | #25 |
From what I understand the cars computers and sensors do not tolerate anymore than a 3% difference in tire diameter from front to rear or rear to front.
09-13-2022, 02:21 PM | #26 |
Yes I have heard that too
16 1SS M6 White
09-13-2022, 03:15 PM | #27 |
09-13-2022, 07:41 PM | #28 |
It will cause issues with the brake lights and truck latch if I remember correctly. Lethal rubbed through his back in the day before anybody knew to relocate it. Ended up replacing the harness. Why not just relocate the harness like many of us have done to accommodate a larger tire? It's pretty easy to do.
2016 NFG 1SS A8
