Homepage Garage Wiki Register Members List Social Groups Calendar Search Today's Posts Mark Forums Read
Emblempros
Old 07-17-2017, 07:18 PM   #449
n813ca
Drives: 2106 SS
It's always hot and humid in Florida
Sent from my SM-G935V using Tapatalk
n813ca is offline   Reply With Quote
Old 08-05-2017, 11:10 PM   #450
Alfieboy
Madman
Alfieboy's Avatar
Drives: 2017 1SS
really
Originally Posted by CruzySS View Post
I can replicate this problem only when the top vent is open otherwise I have no problem.
Obv ya dont read correctly....it is NOT user error..
Alfieboy is offline   Reply With Quote
Old 08-19-2017, 03:17 PM   #451
n813ca
Drives: 2106 SS
Unfortunately my own fix started to melt this summer so I an going to need to get it done. Anyone else get it done yet?
Old 08-19-2017, 06:09 PM   #452
Jones732
Jones732's Avatar
Drives: 1LT
What did you use that melted?
Jones732 is offline   Reply With Quote
Old 08-26-2017, 10:43 PM   #453
n813ca
Drives: 2106 SS
I suggest NOT doing the fix for the window. Got mine back today after a LONG week and it is absolutely no better than it was before!
Old 08-27-2017, 01:55 AM   #454
SuperSteveSS
SuperSteveSS's Avatar
Drives: 2017 ss
I recently got mine back from the dealership for this repair along with a few other issues. Mine still fogs up just as bad as before. The service manager told me they performed the Service Bulletin but also told me that they didnt do any type of software update... It will be going back to fix all the other issues that didnt get fixed along with this upgrade.
SuperSteveSS is offline   Reply With Quote
Old 08-27-2017, 09:04 AM   #455
n813ca
Drives: 2106 SS
There is a software update for the fogging?
Old 09-13-2017, 08:35 AM   #456
ugxvibe
GM Transmission Tech
ugxvibe's Avatar
Drives: 2017 Camaro 2SS
Nope, the software is to correct the 'flutter' of the door when it closes after the repair.
GM:
"Remove both foam pads located on the defrost door to address the excessive windshield condensation then update the software to address the flutter issue that results when the foam is removed."
ugxvibe is offline   Reply With Quote
Old 10-25-2017, 01:42 PM   #457
glovo
Drives: Camaro 2016 1LT RS
has anybody tried removing the fuse for the air conditioning windshield defrost or something?
glovo is offline   Reply With Quote
Old 10-25-2017, 02:32 PM   #458
motorhead
Isn't dew point a lovely thing? Along with automatic climate control. Camaros are not the only cars to experience this by any stretch. Before the days of automatic climate control, all one had to do was to add a little warm back into the air to get the windshield just above the dew point temperature. That's harder to control with how automatic climate control works without making the cabin too warm. I see no way of fixing the isue without some means of achieving 100% airtight enclosure of the defrost door. As someone that deals with airflow every day, I can't believe the fix is to remove a door seal. It should be to install a better one or a stronger closing door. A plastic to plastic seal would be a poor one.
Old 10-25-2017, 05:05 PM   #459
camaro5
camaro5's Avatar
Drives: X-15 Velocipede
The story is deeper than that.
They poorly designed the hvac case so that the mode door could not contain the cfm's at high speed.
This causes a fluttering mode door and the sound that goes with it.
Duh, their solution was to ADD little foam blocks to hold the mode door open so it wouldn't make the flutter sound at high fan speed.
Duh, too many complaints about air on winshield, duh,
TSB to remove added foam blocks, and reprogram bcm to lower fan speed cfm for high.
Duh, it still leaks - sad failed engineering AND follow-up actions.
Door needs more foam weatherstripping. Might be able to get the actuator to pull it tighter.
Worst part: Had this on my new 1984 Camaro Z28, had to get a job in service to get many issues fixed.
And this was one of them. Necessary to remove entire IP to add weatherstripping to door. Worked perfectly. Needed more foam, no more adjustment left.
34 years later! Duh, windshield? Duh, defroster leaks?
g
Go from the presence of a foolish man, when thou perceivest not in him the lips of knowledge
General Motors ASEP, A.S. Automotive Technology, Telecommunications Specialist, CISCO Network Engineer
STANDARD DISCLAIMER
camaro5 is furnishing this information "as is". camaro5 does not provide any warranty of the information whatsoever,
whether express, implied, or statutory, including, but not limited to, any warranty of merchantability
or fitness for a particular purpose or any warranty that the contents of the information will be error-free.
camaro5 is offline   Reply With Quote
Old 01-23-2018, 05:14 PM   #460
GPz1100
Drives: 97 Z28 6MT, '12 G37 6MT
I'm surprised gm's solution doesn't call for windshield removal... Problem solved.
GPz1100 is offline   Reply With Quote
Old 01-24-2018, 12:08 AM   #461
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
GM solution. free rag to wipe the fog off with. lol. with out replacing the heater box there will be no fix.
real ZL1 wheels 285/305 Michelin Pilot Super Sports, Pray ported IM/TB, EFI Tuning Flex fuel kit, American Racing Headers 1 7/8" long system w/ cats H pipe to Hurst Flowmaster NPP mufflers. Full 1LE suspension, with BMR adjustable sway bars and links, Hurst shifter
Old 03-02-2018, 03:47 PM   #462
MXSG
MXSG's Avatar
Drives: 2016 1SS
Originally Posted by PnCRedJwl2SS View Post
I'm using exactly the same vinyl baseboard from Lowe's with the small lip along one edge. I tucked the lip edge into the base of the windshield and have not had it break loose yet on hard acceleration.
As far as I'm concerned, this is my permanent fix. Easy to put in place and easy to remove if I need more defogging.
No fogging at all anymore. I've practically forgotten it's there until I ran across this thread again! .
This was my solution as well. Works perfect for Florida weather. A professionally made cover would be nice though, I feel like a smart vendor could make some serious $ if they offered something.
MXSG is offline   Reply With Quote
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
