03-09-2019, 11:37 AM | #1 |
Drives: 2SS Join Date: Mar 2018
how to separate brake from turn signals lights?
All right, as I live in Europe and my Camaro is US model, need to do a few mods and first is separate brake from turn signal. Do you guys know any shortcut to this job, like staying in the trunk with the stuff and not needing to bring wires from engine bay all the way to the rear?
03-09-2019, 01:06 PM | #2 |
Drives: 2SS FIFTY Join Date: Oct 2018
Hello, I do not know what state of the EU you are, but the normal thing is that if you have sold it in Europe, whoever imported it must take charge of accepting Europe and its approval. If you went for it and imported it, you will have no choice but to go through a workshop that orders the parts to KW Parts and then by certification, pay the engineer, fees etc, etc.
I ONLY FOLLOW GOD. PRE
“LA MAKINA” |
03-11-2019, 01:23 AM | #3 | |
Drives: Camaro 50th anniversary edition Join Date: May 2017
Soleil
_____________________________________________ A car is fast enough, if you fear to unlock it in the morning." (Walter Roehrl) |
03-18-2019, 01:41 PM | #4 |
All right, i brought wires from the front blinkers and also brake signal from 3rd brake lamp and so I managed to eliminate the blue/white wire which was common for brake and turn signal. Problem now is other, the turn signal lights will hyperblink now regardless of what led + resistor I use, or classic bulb or whatever, and I came to the conclusion that the white/violet wire has sth to do with this. On OE assembley, the white/violet wire has 12v all the time, unless brake or turn signal is used, then it shows 0v. Now, as I don't use anymore the same circuit for the turn signals, the white/violet wire stays 12v even when I use turn signals and that is causing the hyperblink, any sugestions on how to deal with this?
03-19-2019, 10:25 AM | #5 |
I think you may need a logic module to stop the hyperblinking. There seem to be a variety of these available:
https://www.amazon.com/Pacer-Perform.../dp/B001S16Z7W I can't decode everything in the Camaro schematic, but I am pretty sure there are some onboard logic modules which are giving you trouble. |
03-19-2019, 10:56 AM | #6 | |
So you know the part that has the T90 is for non US cars, the part that has -T90 is US cars. |
03-19-2019, 12:20 PM | #7 |
Actually after spending hours and hours on testing, it's not quite like that. It is all about the white/violet left wire and white/black right wire which is in some sort of connection inside the tail lamp to the brake/turn led, if I power that led from the front turn signals it won't hyperflash, if I power any other led with or without resistor, or any classic bulb, it will hyperflash! The white/violet wire has permanent 12v on it, when I use turn signal or brake, the voltage will disappear on that wire!!! If I use any other led/classic bulb for the turn signal, regardless if it's powered from front or from the original trunk harness, it will hyperflash again! So, I don't understand much of the schematics but I do know what I've tested myself.
12-08-2022, 06:51 AM | #8 |
Drives: 2019 Camaro SS 1LE Join Date: Dec 2022
Hi.
I have same issue when change my taillight to EU spec on 2019 model. I know that the white/violet wire is the LED feedback signal. How did you solve the issue? Resistor won't work and put the wire to ground after resistor won't work too. Front headlights didn't have the feedback signal which I can use to manipulate the feedback signal for taillight. Oliver |
12-08-2022, 09:10 AM | #9 | |
Drives: '16 2SS M6 Join Date: Aug 2019
David
'16 2SS M6 black on black, SW long tube full exhaust, NPP, Roto-fab CAI, ported stock TB '16 2SS M6 black w/Metallic black stripes, Kalahari, 6 piston front (totaled 1/22/20) '14 Fusion Titanium 2.0T '83 Jeep Wagoneer |
12-08-2022, 09:44 AM | #10 | |
Drives: 2023 2SS Convertible Join Date: May 2009
-Geoff
12-11-2022, 12:41 AM | #11 |
Drives: 2021 300 Join Date: Jan 2015
I see these posts alot, pay the dealer to do it.
12-11-2022, 07:25 AM | #12 |
In Eastern Europe where gm withdrew from? Not a particularly attractive option.
