01-27-2016, 08:57 AM | #1 |
Drives: 2016 Camaro 2SS Join Date: Jan 2016
NPP exhaust question....
I was doing some research on aftermarket exhaust systems/mufflers available for the 2SS. I keep running into an issue with the NPP. Apparently, for some reason, you can get aftermarket mufflers for non-NPP cars only. What would be the reason behind this? And if this is the case, should I order my car without the NPP and use aftermarket exhaust? Or are the benefits equivalent to the NPP? IMO, the less "moving" parts, the less chance for future problems! Also, how is the NPP controlled? Vacuum, electrically, etc.....?
01-27-2016, 09:01 AM | #2 |
Drives: 18 Silverado 1500 Join Date: Dec 2015
Controlled electrically. If you want aftermarket exhaust and sound, don't order with the $800 NPP option. I personally love it and the flexibility. If I want it quiet, no problem. Loud, no problem.
My 15 SS had an axle back. It was loud and sounded good except at 73-77MPH on the interstate. Too much drone.
01-27-2016, 09:07 AM | #3 |
Okay, don't mean to sound like a moron..... But I've heard that terminology thrown around. What exactly is everyone referring to as "drone"?
01-27-2016, 09:20 AM | #4 |
A loud vibration and humming sound that rattles your car. Very annoying. Mine used to drown out conversations and also make you have to crank up the radio or go faster or slower than the speeds that caused it. So on the interstate with a limit of 70, I had to do 70 or 80 and nothing in between. The NPP exhaust was tuned for this car to specifically make sure that there wasn't drone at any speed. The axle back brand I used to have on my 15? GM Performance. Figured there would be no drone, and I was wrong.
01-27-2016, 12:02 PM | #5 |
マスタング = 遅い
Drives: 2017 Chevrolet Camaro SS 1LE Join Date: Aug 2015
That sounds like something else lol...
Drone is just a resonant frequency that is some cars at certain rpms can make for a constant, droning sound. Hence the term "drone"...some actually are okay with it, others hate it. |
01-27-2016, 12:39 PM | #6 |
Should have said rattles your brain...
02-02-2016, 07:05 PM | #7 | |
Drives: 2018 Hot Wheels 2LT Join Date: Jul 2010
Thread Tools | |
