Old 07-22-2023, 05:53 PM   #1
Speak99
Speak99's Avatar
Drives: Camaro 2020 2SS VERT
Doors rubbing on frame
I am getting my door frams and inside the door repainted because both doors did not sit properly in when closed and eventually rubbed the paint off the inside of the doors.
Keep your eyes out for this!
Speak99 is offline   Reply With Quote
Old 07-23-2023, 07:50 AM   #2
ember1205
Hot Camaro
ember1205's Avatar
Had mine fixed two years ago before it was damaged. Saw the discoloration, they buffed it out and added PPF to the rocker. They tapped down the seam weld that was causing the issue and adjusted the door close position. Happened on both sides, I believe there might be a TSB for it.
