Old 02-19-2024, 09:10 AM   #29
FollowMyLine
Driver for Hire
FollowMyLine's Avatar
Drives: 22 Camaro 2SS 1LE M6
Originally Posted by Texan4iu View Post
Looking for info to rebuild my rear calipers (at least to replace the boots and seals) since I'm rebuilding my fronts. Anyone have the part numbers for rear caliper kit & pistons (SS 1LE) ? And are there vented pistons that fit the rear like the Z06 ones that fit our fronts?
Caliper Hardware Kits:
25940448 - Front Hardware Kit w/ Bridge Bolt x2
22813180 - Front Hardware Kit w/o Bridge Bolt x2
22968938 - Rear Hardware Kit x2
Caliper Piston Kits:
23242510 - SS 1LE Vented Brake Pistons
19207043 - ZL1 1LE / BCD Vented Brake Pistons
19207044 - Front 6-Piston Caliper Dust Boots
22968937 - Rear 4-Piston Caliper Dust Boots
22968936 - Rear 4-Piston Caliper Piston Rebuild Kit
Luan Zeqollari
2022 Camaro SS 1LE M6 - Wild Cherry Tintcoat - Delivered 9/20/21
2018 Camaro SS 1LE - Hyper Blue Metallic - RIP 6/6/20
YouTube Channel
FollowMyLine is offline   Reply With Quote
Old 02-19-2024, 10:33 AM   #30
Texan4iu
BLEW BIU
Texan4iu's Avatar
Drives: 2018 2SS 1LE Hyper Blue
Thanks!
Thanks so much for finding & sharing this info! Now if you can find me a place that has the Rear Piston Rebuild Kit in stock. Just kidding of course.
Texan4iu is offline   Reply With Quote
Old 02-21-2024, 08:35 PM   #31
nomile
Drives: 2018 1SS 1LE - Garnet Red
Just replied in another post: does anyone have a source that ships parts that are not damaged? I am staring at five brand new set, and even there especially the middle sized pistons will have some compromises in the form of small nicks around the edges. I think I can make two sets work, but since these are going on a track car I’m not super thrilled. I figure small shallow dense will work fine with the rubber seals and for pistons where only the outer rim is damaged that should also not be a problem.
@FollowMyLine - thank you for putting this list together!
nomile is offline   Reply With Quote
