02-07-2023, 10:21 AM | #1 |
Driver for Hire
Another great deal on Vented Caliper Pistons
For those that need a caliper rebuild anytime soon or looking to upgrade the pistons in the SS 1LE, ZL1, ZL1 1LE or the GM Performance 6-piston kit and any BCD equipped Camaro, Amazon has the OEM vented calipers from the C7 Corvette calipers for a great deal. You can get them slightly cheaper on Rock Auto, but not when you figure in shipping. $118 per caliper for the SS 1LE and $169 for the other fitments.
GM Genuine Parts 23242510 Front Disc Brake Caliper Vented Piston Kit - J6M - SS 1LE GM Genuine Parts 19207043 Front Disc Brake Caliper Vented Piston Kit - J6H/BCD - ZL1/ZL1 1LE or BCD equipped Camaro
Luan Zeqollari
2022 Camaro SS 1LE M6 - Wild Cherry Tintcoat - Delivered 9/20/21 2018 Camaro SS 1LE - Hyper Blue Metallic - RIP 6/6/20 YouTube Channel Last edited by FollowMyLine; 02-10-2023 at 10:23 PM. |
02-07-2023, 11:22 AM | #2 |
Shadow Gray '19 ZLE M6
Interesting. I had the 19207043 part number saved for when I change out my stock pistons for vented. Do you know the differences between the two part numbers?
PPF | Paint Correction | ZL1 Addons Rock Guards | ZL1 Addons Lift Pads | ZL1 Addons Feather Lite Tow Hook | JWM Smoked Sidemarkers | Wildhammer Smoked Rear Reflectors | JWM License Plate LEDs | RotoFab CAI | ADM IC Reservoir v2 | BC Forged RZ05 | SPL Toe Arms | BW Brake Deflectors | CMS Roll Bar | Schroth Profi II ASM Harnesses . Sold: '99 Trans Am (bolt-ons & cam) | '00 WS6 (bolt-ons, heads, cam, 12 bolt) | '05 CTS-V (bolt-ons, short throw) | '10 SS/RS M6 (short throw, CAI, coilovers, LTs, catback, JRE tune) | '01 WS6 YouTube |
02-07-2023, 11:46 AM | #3 | |
Driver for Hire
Luan Zeqollari
2022 Camaro SS 1LE M6 - Wild Cherry Tintcoat - Delivered 9/20/21 2018 Camaro SS 1LE - Hyper Blue Metallic - RIP 6/6/20 YouTube Channel |
02-07-2023, 12:34 PM | #4 |
Driver for Hire
I am going to order both kits, and take measurements and compare.
Luan Zeqollari
02-07-2023, 01:15 PM | #5 | |
Driver for Hire
Luan Zeqollari
02-07-2023, 01:20 PM | #6 |
Drives: 14 Camaro SS 1LE Join Date: Feb 2019
I checked out systems, the 23242510 number appears to be the most current / up to date.
The 19207043 number is more expensive from the dealer, but does not state what it goes to on my end. I checked the bigger Tahoe 6pot kit, and that is not a vented piston kit. Odd. |
02-07-2023, 01:30 PM | #7 | |
Driver for Hire
Luan Zeqollari
02-07-2023, 03:03 PM | #8 |
Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
The 19207043 was used on the CCM brakes of the Z/28, C7 Vette and possibly other CCM variants. 23242510 was used on the iron C7 GS and ZO6 brakes. I'm not sure what the difference is between them.
02-07-2023, 03:47 PM | #9 |
Driver for Hire
I'll find out Friday!!
Luan Zeqollari
02-07-2023, 03:56 PM | #10 |
Oh that's right. I remember hearing the 19207043 was the PN for CCM brakes. Now I'm super curious what the difference is. Luckily, FollowMyLine ordered both! Thanks for doing the legwork for us
02-10-2023, 01:49 PM | #11 |
Driver for Hire
Well, both kits arrived and I took some measurements for us. Now the question becomes, how deep are our caliper pistons. See attached images.
For those that can’t read my writing, it appears the aforementioned CCB kit has larger vents (2mm vs. 1mm) and are 2mm deeper (32mm vs. 30mm). It appears the diameter of each is the same, however the added 2mm of material also adds the additional weight.
Luan Zeqollari
02-10-2023, 01:51 PM | #12 |
Driver for Hire
Now the question remains, what is the difference between the caliper pistons on the SS 1LE, ZL1/ZL1 1LE and the cars equipped with the BCD kit…
Luan Zeqollari
02-10-2023, 02:08 PM | #13 | |
Searching around I did find this post which is aligned with your findings: https://www.camaro6.com/forums/showp...90&postcount=3 That post is from this thread: https://www.camaro6.com/forums/showt...php?p=11188290
02-10-2023, 03:10 PM | #14 | |
Driver for Hire
Luan Zeqollari
