11-22-2022, 10:03 PM | #1 |
Drives: 2022 Camaro ZL1 1LE Join Date: Mar 2021
Avoid this place!
So I take my brand new '22 ZL1 1LE to Herold Motorsports in Houston to have his "H900" package installed on my car. Spencer had previously done a remote tune on my car after I installed headers and Roto-fab intake so I decided to give him a shot on the upgrades. They had my car for over 5 months to do a head/cam swap, blower porting and install a couple other things. This was something that should've taken any reasonable shop 3-4 weeks to do. Especially when all the parts & labor was paid for up front(against my better judgment) After weeks of very little response to messages and catching the owner Spencer in multiple lies, I had to drive 6 hours to Houston to retrieve my car from this con artist. I had made contact with another shop in the area that was familiar with some of what was going on and they offered to take my car in and look over what had been done to it. They found multiple issues with the work that was done. Luckily I rescued my car from this clown before he could get it to the dyno. There's a very good chance that he would've blown my engine with the tuning he had in the car and the half-assed work that was done to it. In his own words, "I was going to shock the internet with these numbers". All at the expense of my engine to promote himself and the joke of a performance shop he has. My car was in no shape to make the 6 hr drive home and barely made the 18 mile trip to the other shop. This is just some of the s**tty work that was found on my car. Instead of using the correct adapter for a boost source at the OEM MAP sensor, they take another MAP sensor, drill a hole in it and screw in a brass NPT fitting with hose barbs on the other side. Then uses a piece of hose to tee off to the meth controller(which had came loose in the pic and was now a vacuum/boost leak) and then finally plug the end of the hose with the MAP sensor to the car. He decided to use a 112mm TB instead of a 103mm TB. So now he has installed an adapter that has gaps above and below the blower inlet which he proceeded to fill with RTV. With this TB and adapter combo, the elbow pipe for the Big Gulp is now jammed in to the radiator and is next to impossible to get the couplers and elbow installed on to the TB. I had originally installed some MSD wires and heat shielding when I installed the headers before taking it to him and had zero problems with the wires. He installs a different brand of wires and now two of them are melted and arcing out on the headers. He charged me $929 for a Katech dry sump pump which is the wrong pump for my car. It was confirmed that a new oil pump was never installed on my engine even though he claims that "he does it on every LT4 cam job whether it was new or upgraded". He finally agreed to refund my money on 11/5 but I have yet to receive it and once again I get zero replies to any messages or voicemails. If you care anything about your car and money, avoid this clown at all costs. Spencer is a habitual liar and I've got plenty of screenshots catching him in one lie after another. If he has ever remote tuned your vehicle, check your knock settings immediately! Your engine would have to be on the verge of something catastrophic before it would possibly detect knock. Hopefully this will prevent someone else from becoming another one of his victims.
Sent from my SM-N986U using Tapatalk |
11-23-2022, 03:25 AM | #2 |
Drives: 2020 LT1 M6 Join Date: Jan 2016
That is an awful experience, sorry to hear. Yeah, looks like that shop became a forum member back in early 2020, has all of 30 posts, and has not posted again on the forums since March 2021. I remember them from the forced induction forums when they were promoting their turbo kit. On a Facebook group, they attempted to try to convince me that forced induction was not possible for the LT1 without regapped pistons rings or forged.drop in pistons. I avoided arguing as I had seen many successful factory sealed LT1s with a blower kit successfully installed and tuned and still running. That conversation left me thinking I would never take my car to them for anything. After reading your story, I looked into them again and verified the have all of 30 posts total on this forum, and they have not posted in over 9 months. Anyways, I hope you can get your refund man, glad you could at least recover the car without a blown engine.
[SBE] ECS NOVI 1500 supercharger, 2" Longtube headers, flex fuel, LT4 injectors, LT4 HPFP, baro breakout
Tune date and results to be determined |
11-23-2022, 05:56 AM | #3 |
File a complaint with the Better Business Bureau.
11-23-2022, 07:16 AM | #4 |
PKG4U
This worked to the tune of one car payment from the dealer in my case. Should of been 3 but was better than none.
2020 Camaro LT1. Bought 10/2020 | GM PERF. CAI | GM Muffler Delete (Performance Exhaust 4” tips). | SOLD 1/2022|
2018 ZL1 Summit White | Bought 1/2022 | PDR, Recaros, Carbon Dash, WeaponX Hx System, Apex SM-10 in ZLE fitment w/PS4S Mods after Warranty “Imma keep it stock” |
11-23-2022, 03:03 PM | #5 | |
Drives: 2023 ZL1 A10 Join Date: Nov 2021
To sum up Im not surprised, it's not only Cars , it's all types of work , construction, plumbing, electrical, I've been told how great they are by so many and my guarantee is better than the other guy. All BS ,you just don't know who to trust doing work. I'm sure there's more good out there , but the 1 or 2 percent of bad spoil it for all. I hope all is working out for you . Please keep this thread going with up dates on your Car.
2023 ZL1 A10 Shadow Gray Metallic
11-23-2022, 04:20 PM | #6 |
Drives: 2022 2SS 1LE Join Date: Dec 2021
I've heard good things from BC raceworks in Houston, never heard of these guys. That sucks what they did to your car and your headaches. I know the frustration of paying someone to get a job done correctly and them dropping the ball.
11-23-2022, 04:29 PM | #7 |
Drives: 2022 Camaro 1SS 1LE Join Date: Sep 2022
5 months? I would become worried after a month.
2022 Camaro 1SS 1LE Rapid Blue 6MT
Looking for traction on wet pavement in Seattle. |
11-23-2022, 05:16 PM | #8 |
Drives: 22 ZLE M6 Join Date: Jul 2014
Definitely report them to the BBB and leave a nice review on yelp. Maybe it’ll save someone the headache you went through.
11-23-2022, 06:01 PM | #9 | |
ryne used to be in cali and he tuned my car years ago he also helped lethal hammer with his car before he moved out of state hes a super good guy and used to tune alot of the fastest ls/lt cars in socal
11-23-2022, 06:22 PM | #10 |
Drives: HBM ZLE Join Date: Aug 2017
Another victim here, my case wasn't as bad but I could go on and on about his sh**y work and crap tuning. Please stay away and if you happen to see people chatting with him on facebook, please steer them clear. Too many good shops in the area as well.
Hopefully everything works out Ryan, your experience has been horrible. Boost mode should have that thing running right! They working almost done? Just a few more examples |
11-23-2022, 07:14 PM | #11 | |
11-23-2022, 07:16 PM | #12 |
11-23-2022, 07:35 PM | #13 | |
11-23-2022, 08:19 PM | #14 | |
