Old 05-27-2016, 08:18 PM   #15
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
Again, i have the v6...i elim the 2nd cats, and now flow straight thru to the square resonators then to the accessory gm perf exhaust which has no resonators, that is the original post on this thread. Someone eliminate the square resonator and it sounded worse.
Old 05-27-2016, 08:32 PM   #16
Modshack
Modshack's Avatar
Drives: 2SS, Hyper Blue
Yup....This thread will better explain the V8 system,,(lottsa pics)
http://www.camaro6.com/forums/showthread.php?t=444690
Steve
Hyper Blue 2SS, 6M, NPP, Sunroof, Nav
Modshack is offline   Reply With Quote
Old 06-27-2016, 06:10 PM   #17
ScottySheppard
ScottySheppard's Avatar
Drives: 2016 2LT RS
Had my 2nd cats removed last week. With the fuze pull the sound is perfect, both tone and volume. Had it done at an upscale speed shop in Reno. Took 1 1/2 hours and costs $160. Highly recommend having it done if you have the performance exhaust.
2016 Camaro 2LT, RS, Hyper Blue, Med Ash Gray, Silver Rally Stripes, Advanti DST Titanum Mirror Wheels, LGX, 6M, IO6, NPP, ZN2
11/30/15--1100
12/10/15--2000
12/16/15--3000
01/06/16--3300
01/07/16--3400
01/25/16--3800 1G1FC1RS8G0142935
01/25/16--4000
01/27/16--4B00
02/06-16--4300
02/22/16--6000
ScottySheppard is offline   Reply With Quote
Old 07-12-2016, 11:56 AM   #18
smalloian112
Drives: 2014 camaro 2LS
did anyone with npp package do this? and if so do the npp exhaust still work, like can I still control the sound by closing the value and opening them? And does it still have the back fire sound when you shift in high rpm for example in this video at 0:30 you can hear the back fire https://youtu.be/mYbFZ9VdpgI
smalloian112 is offline   Reply With Quote
Old 07-12-2016, 01:19 PM   #19
Techn9cian805
The BEAST
Techn9cian805's Avatar
Drives: '16 2SS, '89 Wife
a cat delete wont affect the NPP function, and if anything, it should make that crackle more without the cat. someone correct me if I'm wrong on this one.
Scarlet: 3/3/16: 2SS Red Hot, M6,
Instagram: @luis_what_it_is
Techn9cian805 is offline   Reply With Quote
Old 10-20-2016, 04:54 PM   #20
Whitemaro6
Whitemaro6's Avatar
Drives: 16 Summit white, Ceramic white 2SS
Has anyone done this with clamps yet? and if so what size pipe did you get and what not. I want to do this myself and any help before I crawl under the car would be nice
Whitemaro6 is offline   Reply With Quote
Old 10-20-2016, 07:59 PM   #21
ScottySheppard
Drives: 2016 2LT RS
Originally Posted by Glen e View Post
Correct, and totally reversible for cheap if I sell the car or a dealer wants to be a jerk. Mine are in my workshop storage:
Mine are sitting on the shelf in the garage.. What if you gutted the cats and wielded them back on?????? Who's to know?
11/30/15--1100
12/10/15--2000
12/16/15--3000
01/06/16--3300
01/07/16--3400
01/25/16--4000
01/27/16--4B00
02/06-16--4300
02/22/16--6000
Old 10-20-2016, 08:01 PM   #22
Utah6thgen
Drives: 2016 camaro rs
Has anyone deleted the cats and resonator on the v6?
Utah6thgen is offline   Reply With Quote
Old 12-08-2016, 06:03 AM   #23
mustangcrusher1
mustangcrusher1's Avatar
Drives: 2017 camaro SS blue w/white stripes
I'm sure you can use clamps. I used clamps on my axial back exhaust, they seals fine and NO exhaust leak...
mustangcrusher1 is offline   Reply With Quote
Old 06-07-2019, 07:50 PM   #24
BpTees_1LE
BpTees_1LE's Avatar
Drives: 2019 Camaro SS 1LE
So I know I'm a bit late to the party, but has anyone came out with a bolt on setup yet?
BpTees_1LE is offline   Reply With Quote
Old 06-10-2019, 09:32 AM   #25
cellsafemode
cellsafemode's Avatar
Drives: 2016 Camaro 1LT
how would you have a bolt-on solution without welding plates to bolt to? and if you're going to weld, you can't really call it a bolt-on solution.
I've replaced my resonator with a real x-pipe. Still got both sets of cats. mrt v1 exhaust. It's increased the frequency of the exhaust a bit... But it sounds good still, different, but still very angry and good. I'm not sure it would sound good with stock exhaust since I imagine it would increase that rasp sound that the stock exhaust has.
Old 10-15-2019, 02:45 PM   #26
Luke23
Drives: 2016 Camaro RS 2LT
does it crack/pop alot with sec cat delete + NPP fuse full?
Luke23 is offline   Reply With Quote
Old 12-10-2019, 05:04 AM   #27
Spudsmaro
Drives: 2021 LT1 6 SPEED MANUAL CAMARO
Originally Posted by Modshack View Post
There ae no resonators. Some have confused the secondary cats as resonators though. They're not.
The Resonator is right before the axel back, its a rectangle shaped resonator sits right before the stock muffler and after the secondary cats
Spudsmaro is offline   Reply With Quote
Old 12-10-2019, 08:57 AM   #28
cellsafemode
the x pipe in the v6 exhaust is resonated...
You can replace it with a regular x pipe. This will bring the tone of the exhaust up a bit from wherever it's at.
