Old 02-26-2020, 09:24 PM   #15
ChrisCoffey
ChrisCoffey's Avatar
Drives: 2016 Camaro 1SS Hyper Blue Metallic
Word of caution. Better upgrade tires if you have a few bolt ons with flex fuel. I bought cheapo rear tires to get logging for brett and even going 65mph mine wants to dig and go so spins them a little. Car is entirely different.
I have a flex fuel sensor , 2" headers and x pipe to the stock muffler, rotofab dry filter, new ngk plugs 6 rating, ceramic plug wires, and for that fscm module they are referencing a low side zl1 pump i installed. I have no idea hp and torque but it still has TM on it for regular driving and is evil. You can request on the final tune to get one with it off if you drag but isn't recommend for daily driving and i now see why.
"Ask not what the camaro can do for you but what you can do with your camaro."
ChrisCoffey is offline   Reply With Quote
Old 02-27-2020, 09:00 AM   #16
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Originally Posted by Robby23 View Post
I would talk with pray on that one since it will be a remote tune. Will want A/F ratio to read for tuning purposes. Can always temp install it until tune is done then remove/attempt to re sell used. I am going to upgrade my gauge in a few months to show E-85 content as well as A/F since i cant find a gauge that does just E-85.
I have been communicating with Brett since he bought a 6th gen and he even told me that his base tune gets the WOT AFR pretty close on for mild bolt-on cars. Part throttle and idle can be dialed in by fuel trim logging and adjusting the maf curve. Brett will likely give the OP a base tune without a wideband, he will just require it to make any further fueling adjustments. Again if you go with his proven packages(rotofab, ported IM/TB, Headers...etc) his base tune pretty much puts the fueling where it needs to be. I have seen his base tune break 10's in the 1/4 with one of his bolt-on packages.
Originally Posted by ssmike View Post
I remember seeing somewhere that a '16 M6 is only 2 credits.
It is...2016 requires 1 credit for ECU, 1 credit for TCM, 1 credit for FSCM. Since you are manual you don't have a TCM, so it's 2 credits.
2016 NFG 1SS A8
Options-2SS Leather/NPP
Old 02-28-2020, 01:01 PM   #17
easttxss
easttxss's Avatar
Drives: '16 2SS M6
I just got into mine last week and it took 3 credits, 2 for the ECU and 1 for the FSCM.
David
'16 2SS M6 black on black, SW long tube full exhaust, NPP, Roto-fab CAI, ported stock TB
'16 2SS M6 black w/Metallic black stripes, Kalahari, 6 piston front (totaled 1/22/20)
'14 Fusion Titanium 2.0T
'83 Jeep Wagoneer
easttxss is offline   Reply With Quote
Old 02-29-2020, 08:50 PM   #18
floridanick
Drives: Chevrolet Camaro 2SS
Pray is great 👍🏻
floridanick is offline   Reply With Quote
Old 03-01-2020, 10:01 AM   #19
KingLT1
KingLT1's Avatar
Mine took 3 credits and I have a A8.
2016 NFG 1SS A8
Old 03-31-2020, 06:30 AM   #20
laynlo15
laynlo15's Avatar
Drives: 2022 Lt1 A10
If you don't have a wideband there is no way to tell what your AFR is and to properly log the AFR you have to have a wideband bung.
Old 06-06-2020, 03:51 PM   #21
Jpar890
Drives: 2018 SS 1LE
Just ordered my gauge for when I eventually get a tune. Going with TSP 1 7/8 LT. Are you able to just use the rear o2 sensor bung? Or am I going to have to weld one in?
2018 Camaro ss 1LE
2010 camaro 2ss- speed engineering Lt headers, tune, k&n intake (traded)
Jpar890 is offline   Reply With Quote
Old 06-16-2020, 09:19 AM   #22
wytelightning
Drives: 2017 Camaro SS M6
So to have Pray do remote tuning do i have to buy the $700 kit (i have a 2017)from Skidmark garage and then pay Pray $600 for the tune? I am trying to weigh my options as well for mods going forward (H/C) as i am not completely happy with my current tuner. I'm trying to decide if i have Vengeance Racing do the tune for $990 (they are local and a nationally recognized GM performance shop) or bite the bullet for a few more hundred and have Brett do it. Any thoughts?
wytelightning is offline   Reply With Quote
Old 12-21-2021, 02:33 PM   #23
sswidow
Drives: 2019 Camaro SS
Originally Posted by Shocker91 View Post
hey SSMike brett doesnt pop on the forums to much anymore he is on facebook alot more than here. He can get you squared away with everything you need, for a remote tune you will need a AEM 0334 wideband along with the HPtuners MPVI2, depending on if you have a manual or an auto you may need more than 2 credits to unlock the TCM as well. he has packages for remote tuning. feel free to hit me up through PM i chat to the mastermind himself pretty much everyday in our group chat for Pray Performance.
Hey can you send me your contact info I need a person to help me get a pray tune
sswidow is offline   Reply With Quote
Old 12-22-2021, 08:45 AM   #24
KingLT1
KingLT1's Avatar
email him...
2016 NFG 1SS A8
Old 12-22-2021, 12:49 PM   #25
Puddin
If you can't reach him try his Facebook or contact GPI they're just as good.
Old 12-22-2021, 11:11 PM   #26
Brudda*Termite
Brudda*Termite's Avatar
Drives: 2017 Camaro 2SS
I did the full Pray remote tune package with the AEM wideband, HP Tuners hardware and downloaded the software. I went this way after using a local tuner on a dyno for the flex fuel kit and existing bolt-ons and was dissatisfied. What I know:
- Buy his package deal
- You don't have to weld an extra bung in your exhaust to datalog, you can pull the secondary O2 sensor and screw the AEM sensor in temporarily, per Brett's directions
- Enjoy the improvements and no side effects
Gary
2017 2SS A8 White, Bolt-Ons, Prayed Upon
Brudda*Termite is offline   Reply With Quote
Old 01-07-2022, 01:27 PM   #27
JANNETTYRACING
JANNETTYRACING's Avatar
Hello and welcome.
You can also give us a shout with any questions and you can down load our instructions from our website which walks you though the process.
https://jannettyracing.com/products/...cadillac-cts-v
www.jannettyracing.com
Celebrating 37 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
JANNETTYRACING is online now   Reply With Quote
Old 03-18-2022, 03:06 AM   #28
MakCamaro
Makis
MakCamaro's Avatar
Drives: 2020 Red Hot ZL1 A10
It seems that indeed you don't have to weld an extra bung in your exhaust to datalog, you can pull the secondary O2 sensor and screw the AEM sensor in temporarily, according to what Brett told me as well. For me this is important because I do not want to weld another bung onto my exhaust. However, wouldn't that throw a CEL? I suppose you will have to disable the rear O2 sensors with HP Tuners. How do you do that?
