Vararam
Old 01-05-2020, 10:14 AM   #1
Level300
Drives: 2015 Black rs/ss/1le
Cam kit question...
Hi.
I’m doing preliminary research on what’s involved in putting in a cam and I have a few question.
You can only determine the pushrod length with the new cam installed. Then why do cam kits come with pushrods? I would think cam kits would come with everything but the pushrods. Am I missing something?
Will this press work for doing the trunnion upgrade?
https://www.harborfreight.com/1-ton-..._q=arbor+press
Thanks.
Level300 is offline   Reply With Quote
Old 01-05-2020, 10:17 AM   #2
Black_SS10
SomeguyK
Black_SS10's Avatar
Drives: 2010 Black 2SS/RS
If the base circle of the cam is the same as factory and no milling has been done, then the included pushrods should work fine. But measuring is still smart to do.
You can use a vice and some sockets to install the trunnions. It works the same.
TMS 427, Dart iron Block, Forged assembly, Frankenstien heads, AGP TT 62/62 BB turbo's, AGP/Fore triple fuel system, Tilton clutch, Holley 1 7/8 shorties, Technostalgia tail lights,Oracle, Aeroforce, MGW shifter,Flowmaster, Pegasus subframe bushings,BMR trailing & toe arms,Z28 UCA bushings,Zl1 rear sway bar,Prothane,BMR,Goodridge brake lines,Ridetech HQ coilovers,3.91,Trutrac,billet caps,DSS axles,HE offest,built TR6060,1LE diffuser,Havoc spoiler,SSclones,20in MRR 017, Pirelli P Zero, Nitto NT555RII
More to come.
Black_SS10 is offline   Reply With Quote
Old 01-05-2020, 11:18 AM   #3
Level300
Gotcha. Thanks!
Old 01-05-2020, 01:05 PM   #4
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
I suggest to stick with stock rockers. Or get the caged needle bearings upgrade from a certain vendor. WS6.. or TSP rockers (1.72).
Replace your cam retainer plate with an older design and get regular bolts aka 'NOT recessed'. LS2 dog bone, new gm timing chain and 3bolts sprocket conversion (ls7 iirc). It's a 4x timing sprocket.
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE
Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me.
WHAMMO is offline   Reply With Quote
