12-28-2017, 08:01 PM | #1 |
Drives: Hyper blue 2SS Join Date: Dec 2017
Hyperblue SS paint
The paint on my front bumper seems to have cracked I was wondering if this has happened to anyone else? Does anyone know if this can be fixed or will it have to be repainted?
12-28-2017, 08:04 PM | #2 |
Retired from Car mfrs....
Looks like you hit something. Maybe lightly, but enough to pressure the paint. It will need to be re-sprayed.
12-28-2017, 08:11 PM | #3 |
Do you know if this is something that could happen with cold wether because I haven't hit anything that Im aweare of and does not have a dent or any mark where something could have hit it. The car has other chips from where its been hit with rocks but you can tell where the impact was.
12-28-2017, 08:29 PM | #4 |
Better angle, not so close on where it is on the front?
12-28-2017, 08:38 PM | #5 |
Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
It's possible someone else hit you (while car was parked for instance), which is why you're not aware of it. I have never seen anything like that from just ambient temp swings.
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph |
12-28-2017, 11:20 PM | #6 |
Drives: 2018 SS 1LE Join Date: Apr 2017
Which part of the bumper is that?
12-28-2017, 11:39 PM | #7 |
That is from impact...nothing else will spider the paint that way.
2016 NFG 1SS A8
12-29-2017, 12:02 AM | #8 |
Drives: 2018 1SS 1LE, 2015 RAM Ecodiesel Join Date: Oct 2017
Dealership do any work lately? They could have hit something.
Interesting though. The bumper paint should be somewhat flexible since it is applied to plastic that flexes from expansion and contraction. For that to spider, it would need to be a fairly significant impact and there should be a sign of the impact. Weird. |
12-29-2017, 05:18 AM | #9 |
#TeamBeckyD
Drives: 2017 HBM 2SS Convertible A8 Join Date: Aug 2008
Either someone backed/hit you or you bumped into someone one or something even a small bump will cause paint to crack like that. The ONLY fix is a repaint of the bumper since it's HBM I would be not want to do a blend job.
#TeamBeckyD
**FIFTY HBM 2SS VERT** |
12-29-2017, 06:49 AM | #10 |
Here is a shot from farther away
12-29-2017, 06:51 AM | #11 | |
12-29-2017, 07:04 AM | #12 |
Drives: 2016 Camaro 2SS Join Date: Mar 2016
As others have stated there no way that paint magically cracks like that. Something hit it or it hit something and it does not have to leave a mark. If it was something rubber or wide it would only gently press your bumper lip in and what you have left is how the paint reacted to it.
2016 Hyper Blue 2SS A8,NPP,Moonroof
Pray ported factory intake manifold Ported TB Rotofab ARH 1 7/8 longtubes hi flow cats AFM deleted E85 11.0@124.9 11.65@118.8 pump gas,stock tune/exhaust New combo: Pray Performance Heads/cam MSD intake manifold and Circle D 3C 554/491 on E85 all work & tuning done by Pray |
12-29-2017, 07:32 AM | #13 |
Drives: 2017 Garnet Red 1SS Manual Join Date: Jul 2009
My Hyper-Blue did not crack. The cracks are from some sort of impact.
12-29-2017, 09:18 AM | #14 |
Drives: 2016 2SS / 2004 Tacoma Join Date: Feb 2016
OP - Has anyone else driven your car? These cars sit pretty low, and it looks like someone hit a tire stopper / curb in a parking lot.
2SS, Manual, Blue Velvet Metallic, Medium Ash Grey, Black Wheels, MRC, NPP, Black Bowties, Black GM Tail Lights, Oracle LED side markers.
"I'm going to drink you pretty, beautiful toad" |
Tags |
2016 2ss |
