03-18-2019, 04:06 PM | #15 | |
Drives: 2SS 1LE Join Date: Oct 2011
2018 2SS 1LE 2023 Colorado ZR2 2022 Stinger GT-line AWD |
03-18-2019, 05:03 PM | #16 |
Drives: '18 1SS 1LE Join Date: Sep 2017
The 1LE option is what makes the car heavy.
When I was looking, the 2SS was heavier than a 1SS, but when you looked at the 1LE, it usually outweighed the 2SS.
'18 1SS 1LE Black, PDR
03-18-2019, 09:02 PM | #17 |
From the 2018 Camaro playbook:
03-18-2019, 09:50 PM | #18 | |
Owning SSes for 50 Years
The new ride: 2023 Camaro, LT1, Sharkskin Grey
Previous Performance Cars: 1966 Chevelle SS 4M, 2010 Corvette 6M 1968 Dodge Charger R/T Auto 2012 1SS 6M 1982 Corvette Auto 2010 1SS 6A 1984 Corvette Auto 2016 2SS 8A 1999 Camaro Auto 2017 HBM 1SS 1le 2002 C5 Corvette 6M 2018 2SS 2006 Corvette Auto 2023 Camaro LT1 |
03-18-2019, 10:54 PM | #19 | |
The 1SS is a huge winner for value, nothing comes close to that performance for the price IMO. The 2SS gives you some GT-type niceties that make it more liveable day-to-day for me. I think you notice that it becomes incredibly challenging to go to ever-higher performance, as more HP usually weighs more, which in turn requires heavy duty parts, which all weighs even more, so bigger brakes are required, which also weigh more, etc. It gets into a feedback loop pretty fast, unless, and this is the big one, unless you only care about one metric, such as straight line. I remember back to my WRX mods that made it much faster in a straight line, and I remember hitting the brakes when over 100 and being surprised at how ineffective they were. No surprise due to the size of the brakes, but the point was I should have probably upgraded something other than power first.
2018 2SS 1LE 2023 Colorado ZR2 2022 Stinger GT-line AWD Last edited by JamesNoBrakes; 03-18-2019 at 11:33 PM. |
03-19-2019, 06:23 AM | #20 |
Drives: 18 1SS 1LE HyperBlue Join Date: Aug 2018
The 1LE weighs more primarily due to the rear diff - the center section itself is substantially larger, has larger axles, has a larger differential, it adds the ECU and electronics to run it, and the rear cradle is substantially beefier.
2018 1SS 1LE / HBM - ECS Novi 1500 S/C Tuned by Carl @ CJ Tunes
03-19-2019, 10:13 AM | #21 |
Drives: 2018 Camaro SS 1LE Join Date: Jun 2018
take a pic and send to us, we'll tell you what dat sumbich is
Current:
2018 1SS 1LE - stock Past: 2008 C6 - heads/cam/boltons 2005 GTO - cam/boltons |
03-20-2019, 09:43 PM | #22 |
Drives: 2017 1SS 1LE...makes me go YeeeHaw! Join Date: Mar 2012
Thanks for all the explanation of what the 1LE is.
I think it's exactly what I'm looking for and my Tuesday, is now Saturday, so I'm hoping to be experiencing what the car can do. I'm not looking for a smooth riding DD, as I'm use to driving some stiff suspension cars. My 2016 Chevy Z71 RCSB was smooth running...so I sold it for this SS. I need to feel the road and the dynamics of both the car and the road when driving. Looking forward to be a 1LE owner...soon!
The Thrill isn't around the corner, the Thrill is the corner!
So don't hesitate, just brake late! |
03-21-2019, 11:28 AM | #23 | |
Previous Performance Cars: 1966 Chevelle SS 4M, 2010 Corvette 6M 1968 Dodge Charger R/T Auto 2012 1SS 6M 1982 Corvette Auto 2010 1SS 6A 1984 Corvette Auto 2016 2SS 8A 1999 Camaro Auto 2017 HBM 1SS 1le 2002 C5 Corvette 6M 2018 2SS 2006 Corvette Auto 2023 Camaro LT1 Last edited by ParisTNDude; 03-24-2019 at 09:03 PM. |
03-21-2019, 04:56 PM | #24 | |
Rayvan
Drives: 2018 1SS1LE, Silver Ice Metallic Join Date: Dec 2018
That's like what, a half-tank of fuel? Seems a small price to pay for massive front brakes, better rear traction, a more stout rear-end & axles, and a bunch of heat exchangers/coolant that will never,ever let the car overheat... |
03-21-2019, 07:38 PM | #25 | |
What are you going on about? Dude was worried about 2SS options adding too much weight, I pointed out the 1LE option seems to add the most weight. That fact was proven true in the next post.
03-22-2019, 05:54 PM | #26 |
Rayvan
With a bruised heart and a deflated ego, with sad soul and a head hung low. I apologize to you unconditionally. I didn't even look at what you drive.
03-23-2019, 06:20 AM | #27 | |
It's all good. I went through a lot of comparisons while deciding on my purchase of the 1LE and happened to notice that the 1LE seemed to weigh more than most other Camaros. Thought that was interesting since the car is suppose to be great on the track yet is carries more weight than the others.
04-01-2019, 02:54 PM | #28 | ||
Also on the track alignment, my tires are worn the opposite, I for sure need more negative camber, the track alighnment specs are actually quite modest, 2.5 degrees negative I think, if you drive hard at all this will be beneficial. Quote:
